DIYA store "Wolverine" (Son of Badger) .... suggestions ??
Joined 2016
Updated IPS. TPC and VAS
Hi Guys,
I have created a V2.7 of the Wolverine IPS board that has the TPC additions and the VAS buffer modifications.
I also updated Q12 to a BC550
The BOM and schematic will need review and re-numbering after a review.
P.S. I should become a magician getting that all to fit. :)
  • DIYAampEF3wolverine V2.7 TPC.zip
Joined 2016
I think it would be prudent to consider more factors than just stability compensation, this doesn't seem like it has been properly vetted. Some compensation might be achieved by adding a base resistor to the Vbe multiplier transistor mounted on the driver heatsink and perhaps also the one mounted on the main heatsink. This in turn will probably affect the Vbe multiplier ripple compensation resistor as well.
We can add one (RCC2) to the base of Q104.
Is this what you were talking about?
Hi Guys,
That looks really good Stuart, I'm really happy you you got it all to fit.
I'm currently looking at the bias stability and the effects of the base resistors.
Jeremy
Joined 2016
Im not sure why. But This circuit should sim better than 0.073618% even close to mx power with simple 68pf miller capacitor.
Can you post original file that OS used.
Sorry my mistake, The I had been fiddling around with the DC offset and didn't realise it was way off. 0.001415% is the correct number based on OS original file.
All I have done is set the amplitude to 1.5v to match my testbench and the load to 8 ohms
  • DIYAampEF3wolverinenoservoLT.zip
Joined 2016
Hi Keantoken, I'm trying to finish off the PCB can you please comment on post #1142
Joined 2016
Improvements can be subjective. Some might be inaudible to most. I suppose the question is, will it work, reliably and with good sound quality.
Aspects like DC offset etc.
Who knows, the amplifier is in the developmental stages and a prototype will build build and tested by people who are willing. The feedback from that will determine the next step. Either more simulation and testing or release to the DIYAUDIO store.
More Thermal Sims
So here is a more realistic test for comparing 0ohms vs 100ohms for the driver base resistor.
Ambient is swept from 25°C to 40°C
Driver is 5°C above Ambient, Q103 thermally coupled to the Driver
Outputs are 15° above Ambient, Q104 thermally coupled to the Outputs
Below are plots showing bias current variation over temperature through one of the outputs emitter resistors
Jeremy
I guess everything becomes an argument in audio. As for who knows. It's a blameless with additions. We can become pedantic, but we can also look at schematic and with relative confidence predict if it's going to have problems. Tweaking afterwards not excluded. He already made boards and is asking for advice, maybe just for peace of mind.
Joined 2006
Hi Guys,
Hi Stuart
Did you verify the current on the LED's while the amp is clipping ?
It seems the current will be excessive .... Unless you use a huge value for R17... now you chose 27k .... did you verify the effect of such a high value resistor in the amp SR ?
In my build I found it affects SR if R17 is higher than 6k8
