DIYA store "Wolverine" (Son of Badger) .... suggestions ??
The value should be equal to the effective resistance of the Vbe multiplier. That changes with VAS current, but also trimmer position. So there is a bit of jank to it...
In simulation you can connect a sine current source across the Vbe multiplier to determine it's dynamic resistance and then see the invariance after adding the resistor.
What if we put Rcc in the frontend module? We have to run an extra trace to the Vbe multiplier, but I think that would be fine.
In this example the sine current source has 2mApp and the Vbe multiplier shows 60.4mVpp so the effective resistance is 30.2ohms.
Second picture shows bias voltage with and without the compensation resistor.
I simulated at VAS current 4 mA and bias of 90 mA for both VFA and symmetric CFA. For different bias(different trimmer position) it is not perfect but good enough.
Another long trace ? nah.
Here is Rcc right on the Vbe decoupler (below). C109 is just a 2mm LS
electro. It does not need to be any special thing. I remember I just used
a 1uF 35V wima on my 5 OPS's . Might make ... yeah 2 + 2.5mm for the wima. (below) real tight Vbe now.
They are itching for this project .... let's get er' done !!
Stuarts aligned package with the Vbe update.
OS
OS
OS, you personally told me that, "it would be best to give the user the option to use a film cap for C109"
Were you currently have C109 that doesn't allow people to use a film cap.
Couldn't you move C110 to the left?
This would allow C109 to fit as it was before and give the user the option of using a film cap.
Film Option
OS
Hi OS,
This may work.
What's with the rush for PCBs you guys???
Keantoken came along and made improvements. Dadod is now on board and has improved the design.
Take your time OS. Most of us don't want to see a "compromised" PCB after all the time that you have spent on design over the years.
Side note: I've always admired the way Luxman made their PCB for the amp you posted above. Copper buss bars on rails and output, regulated front end etc.
Also the PCB needs to be flexable for various componts that people want to use eg film caps.
When prototypes are made people like Jeff and Stuart have the equipment to test the amps for fine tuning.
That's my $0.02.
I have people over in the Badger thread saying I am betraying the enthusiast
because of -
-No VI limiters
-No onboard fuses
-Leaving these choices to the builder .... I'm bad and an idiot. 😡😡
My options ?
-$crew them and just go on.
-Design a full protection circuit for the store ??
I look on EBAY , protects , softstarts ... so many choices.
OS
I've always said any rail fuses belong at the supply. If they are going to be there they should be before the wire connecting the amp to protect from it shorting. Also nobody seems to be aware of what happens when one rail fuse blows. Not good without a DC detection system.
There are much better current protection options that VI limiting too.
because of -
-No VI limiters
-No onboard fuses
My options ?
OS
The HB didn't have VI limiting and everyone has got by.
I don't think that the fuses are a big deal. As its easy to add a inline fuse anywhere. Don't most power supplies have output rail fuses.
Besides. The PCB is not really big enough to add anymore comments.
Just adding that last resistor was a squeeze.
Don't stress about it OS.
We are trying to design a ppm distortion amplifier here. So let's keep our focus on that.
Some of the guys on the Badger thread are legends in their own minds. They contribute nothing and all they do is critise others who try to improve things.
I've yet to see them post in this thread. Too scared!
My take on fuses (which I hate) should be on the power supply board in case a wire falls off the amp PCB and touches the chassis. There are many options for protection. Jeff and X sell them, others are DIY, so why complain? I'm not saying that you shouldn't design your own but I'm sick of the negative comments by some members.
