same as D1
easy peasy
it's harder to make those Fugly! wooden cases
Hahaha... those wooden cases are a PITA to build!
Same as D1, great, how do you do D1?
my god, we could have been listening to pure silk a decade ago.
Ahhh, but we already did, Elna silk.
Just not you, and the rest of the herd.
Clever dialog from one of my favorites! Nice to hear from you, Jacco.
I wouldn't have noticed the I/V converter if not for Mark's nifty little DIY Audio newsletter. Thanks for the heads up, Mark!
I'm also having a good time reading about the Explendid amplifier. I'm so used to using FETs that I can't imagine what a decent bipolar amp sound's like...
How about mono block amp with a built in active cross over at the input that would allow simple modular DIY active speaker designs of n-way configuration? It would be nice to be able to use this amp with any pre-amp. Maybe add an incremental power component by simply adding X number of the Semisouth jfet so it could have Y watts of power.
Modularization with easily variable power would be cool.
DAC usage suggestion.
Nelson, in the keeping it simple arean, a box (rackmount preferrable) that would fit into my system would be:
- at least two digital input
- balanced output to preamp on main two channels. (that's all I would use anyway)
- maybe a load sensing switch on the inputs, or RF based switching between inputs.
I see that this thread does not get alot of traffic so here goes.
Nelson,
I admire all that you have offered us here on the low power side. For those of us with fairly inefficient speakers, is there anything coming down the pipe for more moderate power? If not, I understand as my DIY Aleph 2 and my cherished X250 still keep me satisfied. I was just thinking of a project for the future just to keep the juices flowing.
Nelson,
Papa ..... while I was thinking about funny thing that nobody asked - will you have both polarity of Papafets ? , I stumbled on this :
Digital do MaiN - Wikipedia, the free encyclopedia
so - do you plan to make tiny ones , too ?
I didn't make them. I paid SemiSouth a king's ransom to
make them.
Two polarities imply push-pull operation. My research has
not yet indicated that this is where these parts excel.
make them.
hey - even dumbest DiyA - ZM - isn't so dumb to think that you carved them in backyard
these days another one Babelfish J spontaneously mutated to Babelfish J2
( so , another one of 6 planned ) ;
proud maker (spavleski) is smiling all around the head ...... and - believe me - that head is pretty big ....... so is a smile .....
seems that your amps are irresistibly contagious
- DIY progress report
