Hello again
Hello again mattjk,
For R3 i just used the Lo - z rating of 1 kohm.
This works for me.
mattjk said:Thank you! I will build the lo version. What did you use for R3?
Matt
Hello again mattjk,
This works for me.
Sorry
Sorry can't help you there.
I live in Europe.
mattjk said:ok, this is annoying. now I can't find the 3.3n and 10n 1% caps.
I live in Europe.
mouser or digikey
are good sources. you have to search for .0033uF though. that's the trouble i found. some are listed as 3.3nF. some are 3300pf and some are .0033uF. there are 1% values stocked of the 10nF, but the 3.3nF you have to get 2% ones, and hand match them. it is pretty easy w/ a decent hand-held dvm that reads capacitance. the absolute value might not be on, but you should be able to get closely matched pairs. i bought 10 caps, and matched out pairs rather easily. not sure which brands were which...but if you search mouser for the .0033uF 2% you should find them. same w/ .01uF and 1%.
hope this helps. i'm actually building another of richard's designs that uses the same cap values 😉
ahhhh, thank you!
Is this OK?
Mouser Part #: 140-PF2A332F Page 508
Mfr. Part #: 140-PF2A332F Data Sheet
Mfr: Xicon
Category: Polyester Film Capacitors
Description: Xicon 2% Radial Polyester Film Capacitors CAP 100V .0033uF
I know he calls for polypropylene...
The other cap is:
Mouser Part #: 594-2222-460-41003
Mfr. Part #: 222246041003
Mfr: Vishay/BC Components
Category: Film Capacitors
Description: Vishay/BC Components Film Capacitors .01UF 63V 1%
Is this OK?
Mfr: Xicon
The other cap is:
those are the exact ones i bought. i bought a number of different kinds, and think i got some from digikey as well. i went to check the amp...and i ended up using some 400v jobbers from bc components. might be that they were polypropolene, and the others were polyester. sorry...can't remember as it has been a while. maybe check digikey too. they might have been lower tolerance, but as i said...i matched them here. they were cheap enough that buying 10 didn't break the bank 😉
these are the ones i ended up using:
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=246563&Row=220568&Site=US
and
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=246908&Row=220756&Site=US
any of these (or the ones you found at mouser) would work though. if you want to keep them polypropolene...go with these two.
and
thanks!!
I hate ordering all these parts
want to build one for me and I'll pay you? 😉
I can't find the rectifier diodes either 🙁
VSPS v VSPS Ultra
RJM
How does the VSPS Ultra compare in sonic terms with the VSPS with increased gain when using the DL103?
-Bernard
RJM
-Bernard
I found a circuit very similar to RJM's at the Analog Devices website.
http://www.analog.com/UploadedFiles/Application_Notes/28080533AN106.pdf
It's at page 9 of this pdf file. Anyone ever tried this?
maxw said:Newbie question: Is my Stanton 500 AL II a MM or MC cartridge?
I will make this phono pre 🙂
Hello maxw
The vsps is should work fine with a Stanton 500.
Nice homepage by the way.
You did a good job on your gainclone.
Sorry to see you destroyed the looks of you turntable.
Geek said:According to the specs, MM.
I am not saying your wrong but where on that page does it say its MM? just curious as I looked at pages like that before I asked. Maybe the "Samarium Cobalt magnet" bit?
Thank you 🙂ebijma said:The vsps is should work fine with a Stanton 500.
ebijma said:Sorry to see you destroyed the looks of you turntable.
LOL! I bought it when I was 14, stickers were cool back then
maxw said:I am not saying your wrong but where on that page does it say its MM? just curious as I looked at pages like that before I asked. Maybe the "Samarium Cobalt magnet" bit?
The output impedance and output level. 47K ohms and 4.7mV is indigenous to a MM cartridge. An MC wouldda said like 120 ohms impedance (or something low thereabouts) and perhaps 500uV output. Though there are some high-output MC carts.....
Thanks Geek. You learn something new every day 😉
- Analogue Source
- DIY phono preamp - cheap and simple!
