DIY Class A/B Amp The "Wolverine" build thread
1st Chassis is now complete! I am testing the amp on my JBL Studio 590's and WOW does it sound awesome! The SMPS from Microaudio is top notch, comparing it to linear supplies I have built in the past, you would not know the difference, minus the weight and extra wiring. I do have a bit higher noise floor on the left hand board, but I am going to try some aluminum or copper plate to create a shield between the SMPS input and the left channel. I measured the left channel at -91 dbV A-weighted and the right channel at -94 dbV A-weighted, but its below what I can hear through my speakers.
Not sure how that compares with other builds, my wiring could also use a tweak, but I want to run this amp in over the next few days, then remeasure the voltages to see how stable it stays.
The final home for 2 of the amps / 4 channels is going to be for my JBL Project Array 1400's that are being actively crossed over with a Minidsp flex. After listening to this amp on my baby JBL's, I cannot wait to get another amp chassis complete!!
Thanks again to the TEAM for all the work on this amazing amp!
Is there an integrated relay on the PSU which can be controlled by this 12V switch?
I think it is time to read "how to wire" pdf 🙂
Reactions: danieljw and dazcwl
Hi Guys,
I also just wanted to mention that we have a few extra boards left over from the group buy.
So if you would like to order some please follow the procedure outlined in the first post of the second group buy.
The Wolverine 2nd Group buy.
Please don't email me and ask if they are available. Please assume they are.
We will let you know once there is no boards left.
This will save me time answering emails.
Reactions: danieljw and Johno
I have had a few people ask me the difference between RAW and Finished heatsinks, so I just want to clarify.
RAW - As Cut. Needs cleaned up, holes deburred, holes tapped, pin holes drilled and pins installed.
Finished - Plug and Play 😀
Also I have shipped enough of these now, shipping is usually $10 USD anywhere in the world I have shipped to.
Hey fireanimal,
do you still have heatsinks left?
Maybe you could write me a PM (as I am not able to do it myself)
Thanks a lot
Fabian
