DIY Class A/B Amp The "Wolverine" build thread
Joined 2016
Hi Everyone,
I have a new video up on the completion of the main board:
Enjoy!
-Dan
Thanks Daniel, I know how much time and effort has gone into producing these videos.
I hope that your videos are watch by all who build this amplifier as they are a valuable addition to the build guide.
If you guy's enjoy Daniel's videos please take the time to leave a comment. I'm sure that he'll appreciate your feedback. :cheers:
Reactions: 4 users
Does anyone know if I wound the output coils backwards here? urgh fail.
Reactions: 1 users
Joined 2008
Spent today making all the heatsinks and winding coils. I remade the CCS/VAS heatsinks because I wasn't happy with the 1st ones. On a side note the pins for the driver heatsink are a tight fit, I had to use my drill press as a press to push them in, but that's a good thing as they will have excellent contact in the heatsink!
Reactions: 3 users
I have been trying to find a way to reliably isolate metal screws and spacers from pcb tracks on both the input and main pcb's. Ended up using those TO126 plastic mounting washers and slightly adjusting my spacer length. I have a collection of those washers so not sure where to buy. Perhaps this will help if you are stuck.
These are shoulder washers, also known as step washers. McMaster-Carr has a very good selection of them.
Reactions: 1 users
Joined 2016
The reason I say clockwise is because the holes in the pcb are offset from the centreline of the inductor. Winding the inductor coil clockwise will enable it to fit easier.
The other holes in the PCB on the centreline of the inductor are if people want to run their zobel resistor through the centre of the inductor above or below the PCB.
I am left handed and anti-clock is the only way I can wind the damn things tightly, but as @jjs notes, the inductance does not care
Reactions: 2 users
Installation of my output coil,
1.3mm wire.
Used mobile phone style clear glue for the inside to hold it together.
PCB standoffs and nuts etc are temporary until proper bolts and bits arrive.
Waiting on some transistors before I finish the board.
My 14 turn coil turned out well I think
Reactions: 4 users
