DIY Class A/B Amp The "Wolverine" build thread
Hi guys,
I'm preparing to install the output transistors on EF3-4 V. 4.0 boards. I know trimpot R109 gets set back to maximum resistance. What about R11 and R25? Put them back to their mid-points for powering up with the output transistors installed for the first time?
Thanks,
John
Hi John,
I would suggest to leave the DC offset (R25) the same and CCS1 (R11) the same if you are using your lab supply.
After everything is checked and working then reduce CCS1 (R11) only in preparation for the amplifier power supply voltage.
When you change to your intended full supply voltage make sure you reduce Bias and CCS1 again first.
- Dan
That is how I do it too, but I will note we do advise against it in the build guide. Only because if you are a novice builder with only 1 or 2 builds under your belt, we'd hate to see someone make a costly mistake damaging their nice big caps or transformer.
If you are confident enough, with a separate old junk transformer (doesn't need to be big for testing at all, approx. 100VA+ would do it) with suitable secondary voltages and a couple decent size caps lying around, buy a Variac and make an analogue bench supply. Mine doesnt have a current readout only voltage so I use 1000mA analogue ammeters in line with the amplifier rails to get a nice read on what's happening as the voltage comes up. Also use a fast 1A fuse at the transformer primary input (often on the Variac output) and ~2A fast fuses in line with the transformer's secondaries.
Of course, the ongoing use of purchasing boxed bench PSU's with current limiting is the real attraction.
Reactions: RodimusPrime98
Ok guys, it's past 2:00 am here in Pennsylvania, but I wanted to get this one channel prepped for testing with the output transistors installed. So I removed the J103 jumper, the output transistors are installed with non-magnetic stainless spreader washers and M3 split washers. I elected to use sil pads. I checked each transistor leg for a short to the heat sink. No beeps. R109 is set to maximum resistance. The input is shorted. I passed all the resistance tests too.
Please take a look and let me know if you see anything suspicious. Testing will commence with my bench power supply later today (Saturday).
Thanks,
John
I have the one Wolverine channel powered at 30 VDC with the output transistors installed. R11 was almost spot on at 5 V. I have no DC on the output and AC voltage measures zero. I have the bias set to 00.4 mV using R109. I thought the bias would bounce around, but once it settled it just stays there
One thing bothers me. I'm measuring the bias with a very inexpensive Neoteck meter. When I try to measure the bias on my Brymen BM235, I get a zero DC reading. Manually changing the range does not change anything. Yet I can read the 5 VDC between TP1 and TP2 with the Brymen......just wondering....
Bias should be 44.0mV, not 00.4mV. You got a few more turns of R109 to go 😉 pay attention to the scale the meter is showing. (Does it show mV or just V, etc.)
The other meter you have is probably not capable of auto ranging and is only set to measure "V" therefore 00.4mV will show is 0.00V, and it is not set to the correct mV range, or in some cases it may not be capable of even measuring mV (unlikely, unless its a linesmans meter). Either way, it won't show 4 tenths of a millivolt like your pictured meter is, until its range is corrected or you get a meter with more measurement range like the Neoteck.
EDIT - just looked up that Bryman - it needs to be set to mV range and then select manually into DC to measure mV DC.
Meters have ranges they measure in and these either need to be set manually or auto range. It is up to the user to pay attention to what range is being displayed on the screen if the meter autoranges. The neoteck meter you picture appears to be of autoranging type, and it will display mV or V accordingly.
There are several turns but then it will take off. Keep an eye on it, you may need to adjust it back down as it starts to get some heat into the main heatsink.
Later on, when you have the final rail fuses in as per sheet 2 for burn in (you're not quite there yet), this is best done with the heatsink vertical if you can, to get airflow across the fins. It makes a big difference.
Reactions: jminassi
Perfect and keep an eye on it, it may change in 30 minutes or so. For this test, I think you are done. Lower the bias back down to zero and you are ready for your final power supply. Don't forget to remove the resistor in parallel with R17 before applying your final power supply. Also, how many milliamps was the 1st board pulling, write it down, the 2nd board should be close.
Reactions: Mainframe
