My tops are 150w in 12 ohms.. and subs are 600w in 4 ohms .. building 2 amps , one with 3-3 and the other one with 3-4 , makes sense?3-3 = EF3 with three output transistor pairs
3-4 = EF3 with four output transistor pairs
EF3 is short "emmiter followower 3" which is the type of output stage also called a triple.
- Dan
Your mid/highs probably be fine with a 3 pair, and your subs I'd say you'd want a 4 pair at 71V to get the most out of the wolverine which I believe is around 400W into 4 ohm. If your subs are 94db efficient, 400W would be enough.
I don't think you can get 600W from the wolverine at 4 ohms. My calculated max is 527 with 70.7 volt rails. Frankly, for subs, the wolverine is not a cost efficient design, as it is wide-band, extremely low-distortion. Something like 10,000 lower distortion than any sub from 10Hz to over 20kHz. There is a reason digital amps have made a big splash in the sub-woofer market, as they are efficient at high power, and the higher distortion is not a problem in the subs.
OTH, Wolverine is great for the upper/full-range speakers. An EF3-3 can do the job into 12 ohms with the 70 volt supply - I calculate around 175W max, although you probably won't get all of that, depending on the supply.
There is a BOM that comes with the board purchase.
If you want a kit of the board parts (no boards - get them from the previous instructions), send me a PM, as I have a surplus of most of the parts. Otherwise, most are available from distributors such as Mouser. There may be a Mouser BOM floating around somewhere.
I have the YATMA transistormatcher designed by 'Elektrouwe' on Modwiggler, described in details in post #1 via link below:
https://modwiggler.com/forum/viewtopic.php?t=153845
Q: I have quite good experience with this matcher for diodes, LED's and TO92 transistors ect for diff and so forth.
Last amp build I did the DC-offset came out 0.8mV at the output without servo or trimpot to adjust. Normally I'll see within a maximum of 3mV offset straight out the amplifier after matching...
-Does this YATMA-matcher quality for the Wolverine build, or should I follow the matcher mentioned in the first pages in this thread to seek even better results?
EDIT: I use some of the cheap Chinese testers for Hfe-test, just as a guide also
So if i make the Wolverine, and deck it all out, what kind of sound quality should I expect? Is it going to be on the level of a musical fidelity m8s or something similar? Can anyone please comment with some commercially available comparisons? I know it measures well and many are very happy with the sound, but that doesn't really tell me much. Even a, "it compares well with amps $$$$-$$$$$ price range" would be helpful. Thanks for your input
The main problem with most of the inexpensive testers is that the tests are generally well below the actual operating point for the circuit. But they will get you in the ballpark. Transistors are also very temperature sensitive and simply handling them introduces uncertainty into the measurement.
I match mine using one of those socket breadboards and two resistors, two power supplies and three meters. 100k in series with the base hooked to a variable supply, 1k is series with the collector hooked to 6 volts. Meters across the two resistors and the Vbe. Dial the base supply until 2.5 volts across the collector resistor for the 2.5 ma operating point. Measure the Vbe and then the ratio of Ic to Ib for the beta at that point. It's a DC beta, but that is where the DC offset come from so it is good enough. Takes a bit of time, but out 10-20 transistors I can usually find several pairs within 1mV Vbe and a couple of per cent beta. Typically better than you can buy matched pairs.
What kind of measuring devices are needed to build the Wolverine.. and is buying matched pair resisters a good way to go?
I’m in Europe.. kind of think it’s better to get components here.. as for sub duty I’ll build one for the tops and see if it’ll work for the subs.. and if it’s worth the effort compared to what I have driving the subs today.. anyways thanksI don't think you can get 600W from the wolverine at 4 ohms. My calculated max is 527 with 70.7 volt rails. Frankly, for subs, the wolverine is not a cost efficient design, as it is wide-band, extremely low-distortion. Something like 10,000 lower distortion than any sub from 10Hz to over 20kHz. There is a reason digital amps have made a big splash in the sub-woofer market, as they are efficient at high power, and the higher distortion is not a problem in the subs.
You can get by with a decent handheld digital multimeter and a basic component tester.What kind of measuring devices are needed to build the Wolverine.. and is buying matched pair resisters a good way to go?
- Dan
No there isn't. The EF3-4 is lower distortion but not audible. Its more to do with output power and rail voltages, and your requirements that will dictate if the EF3-3 or EF3-4 is more suitable.Is there a noticeable difference in sound between the 3-3 and 3-4?
https://www.lampmani.se/hadex-universell-komponenttestare-1/You can get by with a decent handheld digital multimeter and a basic component tester.
- Dan
This would work?
Depending on budget, I recommend https://www.peakelec.co.uk/acatalog/dca75-dca-pro-semiconductor-analyser.html
And a dedicated matcher board https://www.diyaudio.com/community/...ors-measuring-the-results.307138/post-7404656
But depends how tight of matches you are looking for.
Do i need to use the software on the peak.. i Only have Mac.. and how much are the matcher board?Depending on budget, I recommend https://www.peakelec.co.uk/acatalog/dca75-dca-pro-semiconductor-analyser.html
The parts for stuffing the boards are ~$200 to ~$250 depending on emitter resistor choices, and somewhat on the output transistor choice per channel.Also, what would be components costs for completing the 3-4 boards .. ballpark
- DIY Class A/B Amp The "Wolverine" build thread
