Thank you Maestro ))Great looking build. Who makes the case?
here’s the link, it’s sold in Ebay, Amazon, or direct. Not cheap. They have many different models. I’m currently in conversation with seller about the fact that this case, while very rigid, has pour torsional stability, gets twisted a bit when fully assembled, so one foot is off the ground. He’s thinking how to improve on that. But I do like it’s medical/lab/industrial look and ventilation.
https://www.ebay.com/itm/1250081594...Y3yTBXVSY2&var=&widget_ver=artemis&media=COPY
Torsional twist solved. Easy fix ))). So I do recommend this enclosure.Great looking build. Who makes the case?
Hi Alle-Bay has them, but you have to look carefully. This link shows an "A" series chip on one of the close-ups, but you should probably contact them to be sure:
https://www.ebay.com/itm/234062594780?hash=item367f37c2dc:g:KSIAAOSwqARfvBSr
Apparently, these chips are misunderstood by most of the people selling them. They list the default address as 0x20h or 0x38h when in reality, the default address is 0x27h or 0x3fh. Most also are unaware of the differences between the PCF8574 and the PCF8574A which determines the range of addresses (0x20h-0x27h for the former and 0x38h-0x3fh for the latter). I've ordered displays that explicitly showed 0x20h addresses in the description and the photos, but in reality, they have the "A" series interface chip so the address is 0x3fh. That is why you should contact the seller to verify.
I just see Ralph posted about the updated firmware, which solves this dilemma. If you have the older version firmware (v1.04) you will need to source an LCD with an "A" series interface chip; if you have v1.05 firmware, shorting TP1 to ground will allow you to use a non-"A" series interface chip.
I asked the seller if they are shipping the "A" version and did not receive a reply. I took a risk and ordered one and they are definitely not the A version so we all need to look elsewhere. After a painful search-- the simplest answer is to order a 1.05 version from Ralph Cooke so we don't have to worry about it.
Hi. That’s what I did, ordered from Ralph. And my unit is running fine.Hi All
Aaaaaand it is running! Now to cosmetics and connectors and table body. Again a big thanks to mr. Pyramid!
Hi all. A minor problem (I think): when I press “start”, for the guest sending I can hear the belt slipping on pulley, until platter catches up. It’s a factory Sota pulley and belt. I remember reading somewhere in the threads, that motor should start at only 5v, preventing belt wear. I can see by the current draw that motor pulls about 800 ma at start, and after a second or two it drops to 340 ma. Is anything wrong with my build?
The SG4 does not have the same ramp up in speed that the Condor has as it is designed to be used with 115V AC synch motors as well as BLDC types. The Condor starts at ~5Hz and ramps up to 20Hz and the step up transformers used in some SG4 applications would never tolerate those frequencies. The SG4 does start at full voltage to provide more torque to get the platter moving, then drops the voltage to a user programmed level to reduce vibration which is what you are seeing. It is working as designed.
Thank you. I’ll just buy some spare belts then ))).The SG4 does not have the same ramp up in speed that the Condor has as it is designed to be used with 115V AC synch motors as well as BLDC types. The Condor starts at ~5Hz and ramps up to 20Hz and the step up transformers used in some SG4 applications would never tolerate those frequencies. The SG4 does start at full voltage to provide more torque to get the platter moving, then drops the voltage to a user programmed level to reduce vibration which is what you are seeing. It is working as designed.
Or just apply talc to the belt O expedite slippage, as recommended by several TT manufacturers.Thank you. I’ll just buy some spare belts then ))).
I don't recommend doing this as it can affect both belt slippage and belt creep and will not be consistent across the length of the belt which will adversely affect speed stability. As far as I know, VPI is the only mfr that used to recommend this; their resident expert (Brf on their forum) no longer recommends this either.Or just apply talc to the belt O expedite slippage, as recommended by several TT manufacturers.
Before I obtained factory Sota pulley, I used the one a few people used here, for a round belt, I forget the brand. It was also larger in diameter. There was nearly no slippage on that one, just a tiny squick at the very start. W/f figures were not as good. But perhaps a slightly larger diameter pulley would “tame” the excessive torque at start? I remember Sota using a huge pulley in their Mk IV Cosmos. This is more of a ”nuisance” thing, table/system other wise run great.I don't recommend doing this as it can affect both belt slippage and belt creep and will not be consistent across the length of the belt which will adversely affect speed stability. As far as I know, VPI is the only mfr that used to recommend this; their resident expert (Brf on their forum) no longer recommends this either.
There’s also a very slight noise from the motor. Zero vibration, but slight mechanical noise, resembling “wshshshshh”, so it located in lower table area. I have to put my ears close to motor to hear it. I wonder if my bearings are shot, or may be this is normal. Ori hi inal Papst “pancake” was dead silent.
Btw, to all who are looking for a pulley: Donna at Sota will graciously sell their factory Eclipse pulley, designed for 1/4” shaft, flat belt, and 12” platter. It is aluminum and has two securing bolts. I have her permission to publish this info.
Hi All
I'm having a lot of trouble getting my SG4--rev C + TDA7492 Class D amp 50W + Amgis L01-6362 12V toroid transformer to power a Lenco 50Hz motor.
I'm trying to troubleshoot where the problem may be.
SG4: Measured at the output pins 60Hz : .091vdc : same reading with 1.03 and 1.04 chip
SG4 Output______2.5_______1.75_________5.0
Mark
- is this correct for Rev C?
- SG4 measured after the fixed voltage divider of 8.2K and 1.8K resistors: .008
- Amp output into transformer 1.4 v
- Transformer output before .22uF 400v dc capacitor: 11.4 v
- Transformer output after 22uF 400v dc capacitor: 11.5V
Mark
Your output after the divider looks wrong, to a first approximation, if the SG4 o/p is 1.75 rms,
then you should get 10% of that, or 0.175V after the divider.
Without knowing which TDA7492 amp you're using, make sure there's a capacitor between the
SG4 and the amp, you don't want DC on the amp input, depending on the amp input impedance 0.1uF or more should be fine.
Hi Ralph
Thanks for the quick reply. I apologize for not being clear. The spec output for the sg4 is supposed to be 2.5 VDC or 1.75 v rms. Mine measures. .091 v dc .. far below spec.
After the divider network it measures .008 or about 9%— not too far away from the 10% you mentioned.
On the surface it appears that the sg4 isn’t putting out enough voltage to get the job done. All parts were purchased from mouser per the latest project list they have.
Does any of this make sense ?
Mark
Mark
- Analogue Source
- DIY 4 Phase Sinewave Generator for Turntable Motor Drive
