some people just can't resign the game when the time comes... Anon. vs Anon.: B02 Alekhine Defense: Brooklyn Variation • lichess.org
1) All those shown figures, like a bucket turned upside down, have no meaning when you don’t tell:Modern op-amps have a THD so small that it cannot be measured directly by any instrument.
However, there are methods of such measurement.
These are real measurements
And simulations
- what they are, simulations or measurements
- what was measured resp simulated, i.e. topology of the used circuit
- how it was measured, to convince us of the reliability.
2) One one hand you don’t believe simulated opamp I-V figures that are below so called measured figures of your discrete I-V circuit.
On the other hand you say opamp THD figures are so low that they can hardly be measured.
So please stop contradicting yourself and accept that opamps can easily match your discrete design.
3) I mentioned that in all cases, either discrete or opamp, simulated THD figures below 120dB are to be disregarded, because:
- most of the time they are unreliable
- even more important, they do not play any sensible role in our hearing perception.
Hans
the usual perception of harmonics arises around -30...-60db, anything lower than that being peceived as noise by those wo can do it ...the last time I saw a zxl-1000 for sale it was only 6000 euros because cassette tape can't play lower THD than -42db 🙂
Hi Terry,
What exactly do you mean with influencing the OP Z of a Dac ?
Hans
Hans,
The circuit is essentially a (complimentary) grounded base stage -> folded cascode -> buffer with no global FB or inter-stage FB, just local. I think it's a very cool circuit.
If we consider just the GBS and in it's simplest zero feedback form and measure the OP current distortion it will be lowest when fed from a very high impedance, true CCS DAC.
As the source (DAC) impedance lowers the distortion will go up. The same can be said for a GBS with local feedback (CFP etc) but obviously the distortion will be much lower.
In this case the circuit uses CFP arrangements but fed with CCS from rails instead of the usual resistors, this dramatically lowers distortion further again (I've used it -> powerful design trick)
so it may take a very low DAC OPZ for this distortion to show up.
This I-V could be a good candidate for ES9038 pro in Mono mode. It would be interesting to simulate with 9038's (Mono) OPZ and current swing - see how
it handles the heat!
TCD
Hans, no one said that such distortions can be heard.
But there are places where it is necessary for measuring equipment, for example.
low Distortion Oscillator GS 5534-8 (NE5534)
Cool , good work indeed!Hans, no one said that such distortions can be heard.
Without the discrete OP1005 amplifier which has little THD in gain 1000 these measurements can not be done at all.
There is no integral amplifier with THD as the OP1005.
This is an example where a discrete scheme needs
You mean there's no integrate circuit with those specs .Integrate amplifier usually reffers to a preamplifier plus a power amplifier in one case.
With an integral operating amplifier and buffer you can not achieve such parameters at KU = 1000
Operational amplifiers are compensated for ku = 1 and for Ku = 1000 have 1000 times on bad thd.
Not all operational amplifiers in monolitic integrate circuit form are compensated for unity gain, you find some of them compensated for 5x and 10x as well , but I read your other topic and i know what you mean.It may not be a problem using those circuits at fixed frequencies in state variable filters, i'm not an expert in that , but with the usual DAC audio range you get some even higher range of frequencies than just the audio frequency range to deal with and for that you need stability at least in the audible range and up to more than 44kHz which is a different perspective.Did you run some stability tests as well?
In modern amplifiers with very small distortions there are no compensation for ku> 1
OPA1612, OPA1642....
The OP1005 for KU> 10 does not need frequency correction and there is no problem with stability
I'd like to repeat my Q from #6 as it was meant a serious question ... what do You expect to achieve with such complex designs?
For a audio DAC intended for home HiFi there are numerous simpler designs that sound excellent and that show more than sufficiently low thd figures.
I remember a single power MOSFET iv-design (was a lengthy thread, from iIrc a ausralian guy) with extremly low thd-figures. The MOSFET was biased quite hot and the circuit was quite inefficient power wise.
That should answer Your Q. 😉
Now it'd be kind if You answered my Q.
The circuit in #10 appears overly complex also -I'd rather call it low elegance- as unipolar output DACs like the PCM179x series lend themselves to singleended designs
jauu
Calvin
jauu
Calvin
It may have scientific applications...I did a lot of lobbying around enough quality for audio bellow -90db snr and thd with no appeal to anyone aiming high end multidollar market , but striving for more is a good exercise.
Calvin, if it's hard, don't do it.
I don't have to.
50 transistors for less than 1 euro.
And with an op amp, you can't achieve such parameters.
Whether such parameters are even needed for listening is another matter entirely.
Everyone decides for themselves.
I don't have to.
There is the OP27 (1); OP37 (5) and there was OP47 (uncomp). 1979?
Was discontinued because of no demand
It depends on what the actual sources of distortion are.
There are certainly cases where at G=1000, distortion is not 1000 x G = 1 in magnitude. A good example is some CFB mic pre amp chips.
TCD
but a cfb mic amp beneffits of the input transistors gain...allowing the input trz some 100...400x gain and run the op-amp at 1...5x gain as it's also balanced design
the Q was not about if it´s hard to design ... the Q was about why you design it with that high degree of complexity.
You repeatedly claim that one couldn´t reach similar´parameters´ with integrated OPAmps or simpler designs.
What You have shown so far are some tables which are hard to read and almost impossibe to interpret in first place, and that seemingly only contain THD-figures.
What You haven´t shown so far are the setups You used to derive that single parameter.
You also haven´t shown us other parameters which may play a more important role depending on the application, like noise, offset, input bias, supply rejection, temperature coefficient etc. etc.
If you claim Your discrete OPAmp be superior, than provide us with more parameters and a list of suggested applications, otherwise all further exchange is moot and won´t lead to a decent and fruitful discussion.
jauu
Calvin
jauu
Calvin
These are not small thd amplifiers.There is the OP27 (1); OP37 (5) and there was OP47 (uncomp). 1979?
- Digital Line Level
- Discrete I-V converter
