denon dvd-3910 service manual ?
I only changed to the LM4562 in a couple of PC soundcard and the sound came out clearer.
I changed all the regulators in the PSU (DVD3910),but I´m not sure about the outcome..(soundwise).
Truthfully,there are so many good dacs out there at reasonable prices that it becomes ludicrous at times to mod the audio path when you can just come off the transport into a DAC...I will try it tho.
Thank you very much for the help bro 🙂
I appreciate it
I'll put lm 4562
Another question if you can
You also recommended switching capacitor in the circuit ?
and what brend ?
In the switching capacitors,I would use Nichicon muses..They are perfect and priced reasonable. Truthfully,the logic switching circuit is not going to degrade or improve your audio...That all is done the audio path itself.
There is something that made the MOD
on the dvd denon 3910
after change the op amp from 2068d to lm4562
And can give me the variable changes he made after replacing the OP AMP
Companies capacitors ?
What must change and what can'll stay ?
Help is welcome
If you use a "plastic" cap with the value of 4.7uF you get the -3db point of 11hz.
It all depends on how much you are willing to pay for 2 caps.
I have got no experience of plasic caps,so If sommeone who has are willing to advise.🙂
You mean two capacitors in AUTPUT STAG Large capacitors electrolyte
Can I replace the electrolyte capacitors 100uf-50v in the audio unit circuit
weth
NICHICON muse-kz series 100uf 50v
They are not expensive and I've heard they are good
What do you think ????
And it says 1000 hours
It seems a little odd
Capacitors for quality
