mastertech said:Hi widowmaker you know my friend jean once told me that
a highend amp should be wideband, is yours such an amp
take a look at the stereophile amp of the year Dartzeel has
wide frequency response, that means my friend jean is
right
regards
Sound diapason is: 20Hz-20000Hz...
We're talking about audio amplifier, not about RF...
High End... what is really means High End?
Just take a look...
Ah Yes,
WM, 833 driven by a 6C33B - what are the voltage amplifiers?
No forced air cooling, would that be around 50W?
BUT, this is a very different amp to your error correcting beauty - this has quite a bit of harmonic generation.
Can it compare, particularly on complex orchestral music?
Hugh
Hugh
Oh, GU81M... That a really huge and hard-to-destroy tube. And very cheap here: an original GU81M here costs only 8 Euros!
edl said:Oh, GU81M... That a really huge and hard-to-destroy tube. And very cheap here: an original GU81M here costs only 8 Euros!
where exactly-I'm not so far from Hungary...
Hello,
http://www.dspsystem.hu/index.php?m...=&leirasban=&kerar=&muvelet=&akmn=Elektroncso
more details?widowmaker said:Not exactly...
GU81M driven by a 6S33S 😎
Output power is only 30W... 😉
High-end?
No need, you just have to take a look.
widowmaker said:High End... what is really means High End?
Just take a look...
choky said:more details?
Upupa Epops said:Very nice are these eggs holders, but from acoustic look quite worthless... 😉
The eggs holders are just eggs holdersUpupa Epops said:As I see, some things was the same at all " red zone " 😀
We talk about amps...as it seems...
DoGC, DC version is ready for tests...
Results from yesterday's test:
More bass and detail, compared with basic schematic...
Hi, Widowmaker,
How to calculate the "bridge" in your amp? Between 500R(1k//1k), 47R, 4.5uH, 120pf? In case of wanted to use different values of components, but still maintaining the balanced bridge?
According to mr. Walker...
The condition is:
L=R1*R2*C≈3uH...
But in practice this rule doesn't work properly...
The condition is:
L=R1*R2*C≈3uH...
My simulations suggest that you need to adjust the 47R resistor for the limited openloop gain of the amplifier. A slightly lower value is needed for a lower openloop gain. As openloopgain goes to infinite, the optimum resistor value apraoches the theoritical value: the ratio of the impedances (Rfb1 / Ind) = (Cap/Rfb2).
correct DoGCmaker?
grzz,
Thijs
correct DoGCmaker?
grzz,
Thijs
Peter Walkers patent lapsed a few years ago, odd that there have not been a few commercial examples since then.
You can see in the revision history of the Quad 405 and its decendants that the "dumping" output stage was gradually biased from the original "big deadzone" to almost class AB.
Hobbyists can grab some interesting jfets including an n channel matched dual from any old Marantz CD player HDAM module
Here's the current dumping idea, but do not use inductor. Without inductor, strange noise appears
http://www.diyaudio.com/forums/showthread.php?s=&threadid=15742&highlight=
The inductor was an elegant way of getting the Zobel network that you need anyway and low frequency efficiency. The real Quad inductor had a parallel resistor to damp its self-resonance.
The weakness of the original Quad 405 was the LM301 opamp in the front.
Selamat tahun baru
Selamat tahun baru
- Death of Gain Clone
