Dead KEF X300A - what to do with them?
Given they are only 39 US$ each, already have the PCB, the ready to mount back panel , terminals, even wiring ready to plug-in at the speaker itself, personally I would buy the originals in a jiffy.
Doubt you save money after adding all costs.
In general the "electronics" part is the cheapest one, the "mechanicals" being the most expensive and inconvenient, by far.
Of course, the decision is yours.
And it guaranteed fits your speakers.
As of finding which is which, touch each speaker terminal pair with a 9V battery, tweeter will "click click", woofer will "thump thump"
Paid $2 at local flea market, Matsushita chip amps.
20W/channel/8R minimum.
Needed a bath, is all.
Rigged to my computer with 3.5/RCA cord, nice.
The output of the Zen DAC can be switched between fixed and variable, meaning the iFi can operate as a digital preamp if you so wish.
That means you can connect it to a power amplifier or to an integrated amplifier.
This is a diy forum and I don't claim to be knowledgeable about ready made equipment.
If your budget is tight, you could go down the second hand route or perhaps an amp like this would fit your requirements:
2 Channel Amplifier Stereo Audio Amp Mini Hi-Fi Class D Integrated TPA3116 Amp for Home Speakers 50W x 2, with 19V 4.74A Power Supply - Fosi Audio V1.0B Black: Amazon.co.uk: Electronics & Photo
Since you say you're not familiar with the software layout, I've attached a schematic which shows clearly how the crossover circuit is wired to the speaker input terminals.
The resistor is not shown, but you'll know where to put it! 😎
Nice, it worked! 🙂
Now I need to get different MDF or so, OSB looks ugly when cutting the holes.
Thank you very much guys, I really appreciate your help with this project! Learned a lot 🙂
