DB Drive 1200
Perry yes you are right 9540 sorry . The fets are 100% but across the resistor of the 9540s gate they mesure 3.56 volts. On one output driver board I have two transistors that are shorted (1023) cross pin 1-3 0 volts ? Other board same transistors have .650 volts on them .
Ok Perry heres what I got of all the out put fets
* other side of resistor -37.4 it jumped to -36.4 on the gate for alil bit and back to -16.42 and it stays there turn off power turn power on still at -16.42
left side 9640
1. -16.42*
2.-37.6
3.-37.6
640
1. 37.5
2. -37.6
3. 37.7
right side
9640
1. 37.7
2. -37.6
3. 37.7
640
1. -37.6
2. -37.6
3. -37.6
Also I think I burned out the NJM 13600 all the ic on the output side have +/- 2 volts . On your repair disk is there a page with the NJM 13600 inputs outputs ? Thank you Perry .
I don't think I have any voltages for that IC. What do you mean you have ±2v on the output side?
Do you see signal on the top row of pins or on the bottom row of pins?
Do you get the same DC voltage on ALL of the 9640s on the left side? Check the pads if there are empty 9640 locations.
On the voltage regulators for the output ic's ±2v. All the ic's have this voltage and R52 and the other resistor get hot again, cause I think I burned 13600 need to check it out. I smelled smoke and on the sides of this ic it has alil bit of powder from the ic .
No signal on any pins . but then again low voltage ±2v.
Yes on the left side it has same voltage , left side has no fets . right side has fet in place .
Remove the 13600 if you think you damaged it. Does the voltage go back to what you'd expect on the regulators?
On the side of the amp with the 9640s that have -16v on the gates, do ALL of the gate pads/legs of the 9640s have -16v or do some have -37v?
What is the total number of 640s and 9640s on one side of the amp?
