The latest firmware for dac1541 incorporates the new 4K length FIR filters. They are very good indeed. I personally prefer the minimum phase filter (green LED). The piano strokes, guitar plucks, vocals are very realistic, sometimes eerily lifelike.
I’m not too sure about dam1941 but I believe the same 4K filters are there. Probably Soren can confirm.
Prakit what filter are you using. Your comments would be useful especially since you also had a 1021. How do the filters compare?
I have gone thru all 24 pages of this thread and nobody seems to have made any mention of filters. The 2018-10-08 manual of the 1941 makes mention of four filters in the uManager Commands section but refers to dam1121 in the Updating Firmware section. Can I assume that updating the dam1941 software is identical?
Are the filters on the dam1941 same as the dac1541? What is the default filter setting?
There are some not so flattering comments about filters used in the dac1541 posted around December 2017, but I see mention made on the Soekris website April 6, 2018 that they have been updated. Are these in the dam1941? Any user comments?
Thanks.
nash
The dam19x1 use same new filters as the dac1541. People seems to be happy with them.
Thanks Soren. What is the default filter setting?
nash
nash
On power up, default if F5 - mixed linear/minimum filter. But you can set another power up default.
That would be orange as per the dac1541 manual. Thanks.
nash
Thanks.
nash
I think your questions were well answered. I just want to add that it could take sometimes to figure the effects of each filter. With 1021 I preferred Minimum Phase by far. But I found the degree of preference is much less with the 1941. The default mixed Linear/Minimum sounds good to me. I have not tried the 4K though.
Prakit
Ghost volume status messages
Søren,
What the heck these volume status messages (V+00, V+64) at DAM1941 init?
I built display and IR remote control for DAM1941 using Dimdim's ArDAM_Lite panel with Arduino Nano and 1.3" OLED.
Working perfectly, but managing these "false" init status messages reserve unnecessary storage space in the very "narrow" Arduino Nano.
It was necessary send volume ( for example -3) command to DAM to get "real" volume status message.
Søren,
ArDAM Lite controlled DAM1941
If anybody want to use Dimdim's ArDAM Lite to control DAM1941, I wrote there about my system:
https://www.diyaudio.com/forums/group-buys/306521-gb-ardam-lite-bare-pcbs-18.html#post5701320
Do you use i2s?
How on earth can he use i2s?
- Vendor's Bazaar
- dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
