Lot of animosity for a question I asked because I want to learn and check things before instead of haphazardly connect things. 100K was for my integrated amp, a Harman Kardon PM665. Manual says "Main in" 0,8V/22k Ohms impedance. It didn't physically fit, so I maybe wanted to try and put it within the dac enclosure and connect that to the power amp section negating the preamp because the amp has that ability. I thought that if the volume control on the amp was 100K this would be pretty similar in this situation.
I also think it's kind of bizarre that I explained that I knew about the digital volume control and why I wanted to try an analog control (because I might want to make a complete preamp out of it that can also have a phono stage connected to it. so I might also add a buffer or not.) but still had to read about the volume control being good and sufficient.
100k is an extremely poor choice for a volume control that is not integrated within the power amp. Yes, it will work, nothing will blow up.
This sounded kind of passive aggressive to me but was helpful thank you.
I don't get why people have to be so rude and/or annoyed by a question from somebody that doesn't have the knowledge about a certain thing and tries to get some knowledge by asking it in a forum that has people that can enlighten them. I thought this was kind of the point of a forum.
