Dear Quanghao,
I was checking the voltage supply for each regulator. I found that the voltage labelled '3.3V_CL' only got 2.1V. I think this is the voltage to supply to the clock crystal.
What should be the correct voltage supply to the clock ? Is there something wrong ? I thought it should be 3.3V.
Alan
Alan
Thank you!
Thank you Alan! I was a bit confused about labeling the passive output boards as I/V since it is already in volts. Now everything is clear. Thank you Quanghao and Alan!
http://www.diyaudio.com/forums/atta...s9038-pro-group-buys-out_ll1684-es9038pro.gif
Here is a pic. Not very sharp
Transformer questions
Hello Quanghao,
Does the transformer need to be dual secondaries or can I use a transformer with a center tap? Thank you!
Bao
Hello Quanghao,
Bao
Hello Quanghao,
Bao
center tap . it is ok
thanks
Dear Quanghao,
Alan
Here is the voltage for the Clock: 100MHZ. 3.3V
Find out carefully, check out C42. Maybe it caused the error! Or pins of LT3042 (IC5).
Touch or touch! Find it.
If you have capacitor 1206 = 10uF (C42), replace it!
thank you very much!
Hi Quanghao,
The C42 is an SMD capacitor, there is no indication of the value of this capacitor. You want me to remove it ?
Hi Quanghao,
Yes , remove it now and check 3.3 v.
Hi Quanghao,
I removed C42 and the voltage is now 3.3V. Thank you.
Is this problem happening to all the boards you sent out already. If so, you need to inform all the other buyers to remove C42 from their boards. For those you have not sent out, you need to remove C42 for them.
Removing C42 is easy, first locate the indicator which said '3.3V_CL'. The LT3042 regulator next to this indicator is responsible for the 3.3V for the clock. C42 will be next to this regulator. To remove it, hold C42 with a plier, use a solder iron to heat one side of C42 for a few seconds, then C42 will come off easily.
Hope this helps all.
Hi Quanghao,
The problem you say, is not so. The C42 capacitor is not fault.
Cause the capacitor to fail in production.
Which is my experience.
You need to find another capacitor to replace: 1uF to 10uF / 6.3V.
thank you again !
Hi Quanghao,
thank you again !
Hi Alan ,
Thanks ,picture pls
thank you again !
Hi Quanghao,
Remove C42 is easy. But put back another one is very difficult due to such a small size. My eye sight is not good and my hand is very shaky to put back such a small SMD capacitor.
Anyway I will see what I can do.
Hi Alan ,
Thanks ,picture pls
Hi Myint67,
If you have the ES9038 board with all the connectors (SPDIF, AES ...etc) right on your stomach, The '3.3V_CL' indicator is just above and left of the USB connectors.
The voltage there should be about 3.3V. According to Quanghao, the failure probably only happen during production and WILL NOT happen to everyone. So if you have 3.3V, there is nothing to worry about.
Hope this help. As I need to find a camera with macro lense, let me know if you still want a pic.
Networks?
Why the network on the input of the tranny to ground?.....I see in the data sheet for the tranny that they recommend a 1K and 3nf for best square wave response on the output as you show. What does it sound like with and without the input and output networks? Do we really need them?
Hi Quanghao,
Can I use an Electrolytic cap 220uf for C42 ?
Thanks.
No 1 -22uf mkp the best .
No need use that.
I see the sound I love.
Hi Quanghao,
Have your tried to implement the ES9038 board with electrolytic capacitors in the power supply instead of Aluminium Polymer capacitors ?
I have an impressions that Aluminium Polymer capacitors are not best use for audio circuitry.
- Group Buys
- DAC ES9038 PRO Group Buys
