DAC-ASH (dac-end 2 up date)
Lots of people on this forum are building the DACEnd or the DACEnd 2 by Andrea Ciuffoli.
I read a lot about parts, upgrades and so on. But it is hard to find any results, reviews or comparisons of these DAC's on this forum.
My question is, are there already people on this forum who are using one of these DAC's in their Audio System, with good, bad or exellent results?
I'm just waiting for Bud P to get back to me with transformers and I'll get this up and running in no time🙂
All things being equal this DAC should sound fantastic the way it's implemented🙂
I'll let you know!
No!
R1 set current for SSHV Supply =22 Ohm, Ia ( I total ~95-100 mA)
So Iv need total= 80mA, 1/2 Triode 6h30 need 18-20mA.( the sound is the most )
And Voltage at Anode =90-100V,
So voltage at R 22, 21,37,38 =3.8-4V , and R =200-220 Ohm, it is ok!
You see it???
Ok I got the correct anode voltage 90V now. So the current through each triode is 2x20mA ~40-50mA, power on 6 anode resistors //18K total=3k, is IxIxR abt 7.5W and per anode resitor 7.5/6 ~1.25W less than the 2W rating, but resistors are quite hot, is this ok ? Also the 22R 2W dropper resistors R15/R31 are also quite hot.
This image, you can see IV stage
Hi dirkveenstra!
you can see some link please:
http://www.diyaudio.com/forums/quanghao ... li-87.html
Post 862
http://www.diyaudio.com/forums/quanghao ... li-94.html
apelizzo post 934
http://www.diyaudio.com/forums/quanghao ... i-125.html
Post 1250 agithegreat
http://www.diyaudio.com/forums/quanghao ... i-140.html
Post 1394 -flocchini
http://www.diyaudio.com/forums/quanghao ... i-152.html
Post 1520 - ksnider1
http://www.diyaudio.com/forums/quanghao ... i-154.html
post 1539-Yunick
Thanks!
Thank you very much for your info, I will read these posts.
I'll let you know!
Nice, I'm very interested in your opinion.
I'm just started with this project, it can take some time, because work is also important.
I'm building the DACEnd (not the DACEnd2)
You will hear from me when my DAC is running.
Do you use the 'Andrea Ciuffoli' PSU layout in your system?
Not DAC-ASH is like DAC-END 2, because I use all Salas shunt for this project!
Yes!
you can see some layout by me, with design by Andrea and Salas in my web:
Quanghao.com
My friend like dac ASH
mengkut comments:
"Specific Hao said," check all of the CS8414 leg yesterday read the datasheet of the SC8414 not understand why it boiling like FM. I suddenly flashed on the son ic ic is glued, not welded his so familiar ...? How is this the end hooks attach all of the very first leg has finished plug. The feeling of specific know how when you then hear the melodious music scholarships emit no bass? then than 11g, Bear wakes up her sleeping Scholarship grumbled they are considered ideal world cup! so you hear a line more than one CD at 3 am. As of late or hear more! ơi sweet sound is sweet! bass filled with deep powerful compact, high bar separate treble English, and the singing of capenter alas, how that so sweet and gentle! ball really worth!
The instruments are registered on the board go fast hands, happiness is waiting at the front! "
