D AMP is back !!!
Hi, here is schematic (last version):
Hi.
Does anyone know who sells IR20124 and PHP28NQ15?
IR20124 seems to be available but the MOSFET is not on the current Philips (NXT?) site? Could someone recommend a replacement? Perhaps one that could withstand 200V instead of 150V.
Regards TroelsM
Hi Bender, your level shifter seems superfluously complicated. Zener+diode etc. Did you try simply dc856 +two res? BTW, BJT could be less warm, if its base =319_pin#3, emitter =319_output node, and 2kOhm from 319_output to GND. What is the goal of the R17;18? Try replacing R10 to 10kOhm, for 319 input current matching.
Hi IVX, you are right. Levelshifter came from early experimental proto (where i use low voltage BJT & experiment on rise and fall slope🙂),
So there is no any reason for such complicated schematics, 1 BJT+2 res function perfectly normal. Thanks for advice, i'll try to do it.
To be honest, i didn't think about R17R18 :clown:.
mehrdad, unfortunately i haven't free time for this project, i'll post all schematics & results later.
Good design. I also would like to design, but H-bridge with paralleled Schottkies at each FET, on two layers. But the track layout is still not so fine. I also would like to measure the current of the bridge, so current ringing must be minimal. Your design, with the ground plane behind the fets is so good. In the v2 design you doubled the fets, or put something new component to the board?
