Mindcrime -
You might take a look here:
http://www.zaphaudio.com/
Scroll down to Hi-Vi B3S Single Driver System
Available and described here:
http://www.parts-express.com/
Part # 297-427
I have no personal experience with that one.
Part # 297-427
I would recommend the Alpair6 (see above), or the Vifa 9 BGS 119/8.Mindcrime said:I can't seem to find any W3-871S around.. can somebody suggest a suitable replacement? I built my Needles with the FRS8's, but would like to try something a bit nicer... Thanks in advance! 🙂
The B3S is not balanced in the high end, and has a poor low end in the Needle. both the above are excelent drivers and suit the Needle very well.
Henkjan said:I would recommend the Alpair6 (see above), or the Vifa 9 BGS 119/8.
b.ugger... just ordered the b3s for my under-construction needles! oh well, not exactly an expensive mistake at $19 each 🙂
edit: hmm seems like i can't find either of those drivers in oz yet. guess the plan with the needles will be to live with the b3s until i can get some cheap 871s...
Henkjan, what software are you using for your simulations?
I would have exected that Dan Archer should have the Alpair6s in by now...
As I write this, I just paused from some measurements on the Alpair6 in the Needle... I have notch that at least measures fairly well, so after some more finetuning I'll hook up the other speaker and listen....
for simulations I use MJK's mathcad sheets.
notch filters I don't simulate, I just measure with a box full of caps&coils available...
btw: I could send you a pair of W3's but I expect that for the shipping costs you can by the Vifa or Markaudio localy 🙄
I've got Omnes Audio BB 3.01 drivers, not in needles but in BIB's, they're very nice. Faultless as far as I can hear, though not quite as sweet on some instruments as Fostex.
Henkjan said:I would have exected that Dan Archer should have the Alpair6s in by now...
According to Dan, the alpair6s will arrive around the end of this month.
thanks for the w3 offer, however shipping would be prohibitive yes!
I just checked: shipping from here to Australia is 24 euro's for a parcel up to 2kgchylld said:thanks for the w3 offer, however shipping would be prohibitive yes!
the first notch did not quite sound top (so some work to do), a bit of a nose sound to some voices, but at least I got some CD's to judge the Alpair6... I'm already impressed... well balanced, powerful (for the size that is) low, beautiful detailing... yes, worth the extra investment compared to any other 3" driver I've heard....Originally posted by me
.... some measurements on the Alpair6 in the Needle... I have notch that at least measures fairly well, so after some more finetuning I'll hook up the other speaker and listen....
Henkjan said:I just checked: shipping from here to Australia is 24 euro's for a parcel up to 2kg
works out to about AUD47... may not actually be that bad value given that local shipping here for 2 3" speakers is AUD15.
that said, i'm sure some 871s will make themselves available in the future... so i'll probably try the alpair6 units first. after i have a good listen to the b3s though 🙂
read this thread for the first time from start to finish... seems to be an eternal thread!
didn't find any concrete results from using the hivi b3s in the standard needle design, but i'll be sure to post my results as soon as my hivi's arrive! mine is the standard design, except with front and back using 16mm mdf as well (looks thinner in the pic below since the inside is chamfered 45 degrees)
waiting...:
waiting...:
finally have my needles up and running, with hivi b3s drivers! thread on it here. a quick pic:
overall impression is that they're the best speakers i've ever owned, and create quite an impressive 'wall' of sound especially for such small drivers. that said, the sound is a bit edgy at the top end (even with zaph's breakup node filter) and the bass really needs a hand from my subwoofer.
so even though these are the best speakers i've ever owned, i can quite easily imagine how they could be better.
dan from darcher audio has told me the alpair6's are really in a totally different league to the hivi's, and henkjan if your simulations are anything to go by, they should prove stunning in my needles!
(henkjan, i assume you also tried the w3-871s in your simulation?)
thank you very much for this, henkjan, it is extremely useful.
i have combined all 4 graphs into one:
from top to bottom, they are:
1) alpair6
2) bb3.01
3) w3-871
4) w3-1285 / hivi b3s
it appears that a driver change is definitely in order, especially when only the b3s and alpair6 are shown:
1) alpair6
2) bb3.01
3) w3-871
corrected the first graph above, the w3-871s was horizontally misaligned (please refresh to see the proper graph)
henkjan, is it possible to show the Vifa 9 BGS 119/8 simulation as well?
thank you for the extra graphs!
there are now too many to show on one graph, but it is still clear that the alpair6 is the best choice. frs8 and b3s really seem like horrible choices!
unfortunately i cannot find an australian source for bb3.01 or 119/8... so it seems the alpair6 is the clear winner here as soon as dan gets some in stock.
- Full Range
- Cyburgs-Needle for Tangband W3-871S
