Crossfire vr4000d
Arite,
I pulled each component for the gate drivers and they checked good.
Attached is the drive signal on pins 9 and 10 of the 494. (Pins lifted).
I’ve also taken a close up of the components and drew a quick sketch to try to figure out why this is not working. Seems this is not the traditional EF pair.
I checked, and this transistor has pin 4 ( via a 4.7 ohm resistor) on the collector and Pin 14 on the emitter.
I pulled this transistor and powered up, it pulled the voltage on the power supply down to 7v and the amps went up to 13.4a.
I had the scope across the gate on the PS FETs.
