Complete Novice Needs Help
OK , fets are ok .... Had them working ,but no audio signal .
I have been try to glean the voltages from the Algar schematic and apply them
to Brian's boards.
Gate , Q4 to R17 = 4 VDC
R 18 to R 17 = 15 VDC
Gate 3 to R 4 = 18 VDC
Q3 Drain to R 8 = 3.6 VDC
R 5 to R 4 - Z5 = 16 vdc
My output voltage from PSU is 30.44 VDC so my readings will be relative as the Rail VDC on the Schematic is 26.00 VDC ....
Am I driving down the right Street ?
Rich
If you are using the Chipamp schematic, yes. 47K should push the bias down enough for start up so you can get it set up to your chosen bias current. Your rails are quite a bit higher than normal so don't over do it with the bias.
The 500 ohm trimmer should enable you to eliminate any offset once it's warmed up.
Best, Bill
Good morning all !
I have just rebuilt my Aleph 30 . It works great ,but I still have a small thump when I turn it off . I guess the caps need a bleed resistor on them ?
If so , what value and where do they go ?
`thanks for your time , Rich
Yes, bleeder as seen in F5 power supply. 2K2 / 3W parallel each 1st capacitor (V+, V-) after rectifiers. You can also use thermistor ( CL-60 ) in series with mains, to get the thump damped.
Best,
nAr
Say, I have noticed differences in part numbers between the original Aleph 30schematic and the part numbers as used in Brian's boards. I have searched the chip amp site, but only find BOM lists.....is there a schematic somewhere that shows brian's version? I have the original schematic, just not the version for Brian's boards. I am easy enough to confuse already...
Thanks,
Russellc
Best, Bill
I'm sure Bill no doubt had it.....
Russellc
