Jocko Homo said:You are missing the point, Elso...........
[snip]Are you going to make me build one and measure it just to prove my point?
Jocko
Why not Jocko? Then I could buy it off you afterwards. I mean, since it will be on a shoestring budget anyway... I need one for my Rotel 965...
Jan Didden
You better measure mines!Jocko Homo said:You are missing the point, Elso...........
Jocko
[mods/technical supervisor, this forum stopped sending me email notifications of new posts!]
Jocko Homo said:
I would be certain that the same ol' 74HCU04-type clock, all by itself would be better. Even if fed from a 7805.
Did that a few years back when the first Trichord clock caught my interest. Yep, it was a considerable improvement. Went on to better things later, but even this simple cheap mod was well worth while.
Jocko Homo said:I have only seen a few CDPs that use an external Pierce, and when they do, they muck it up by using all 6 gates in the chip.
Here's one:
http://www.diyaudio.com/forums/showthread.php?postid=246092#post246092
See the attachment.
But it only uses 4 gates.
Bad Clock
I consider that a pretty bad clock!
Extreme_Boky said:Yes, cheap but pretty good, question is would it work > 20MHz if we further reduce R500 and R501?
Extreme_Boky
Re: Bad Clock
KC7 definitely sounds better than that clock! I'm tempted to try using only one gate for all three clock feeds, but an unmodified Marantz CD-75 MkII sounds so much better as a transport than the Pioneer that I can't be bothered.
Elso Kwak said:I consider that a pretty bad clock!
Hi Elso,
I know it’s nothing special. I consider that VERY good clock for the money. 100's of kHz to above 20MHz (? haven't tried this yet! - max. I ever needed was 16.9MHz) with possibility to drive more than one "user" if needed. With only one user and unbuffered IC the noise is pretty good as well! I use this on the cheap and the results are very good. And it costs me around $A35 with low noise power supply, PCB and parts.
For expensive mods I still use LC XO3 but ONLY because it's easy to get it in Sydney.
I think your Xtal load solution is VERY good and power supply as good as others; however I do not have time to assemble your clock when I need one for modifications. Ever considered making ready-made product for us? You also mentioned new revision? Could you tell us more?
$A375 for LC XO3 certainly hurts a lot and I will find time to make something myself (unless one of you guys do it sooner and make ready made product at a reasonable price!)
For my personal use I found approximately 5 months ago (after a lot of careful consideration what to choose for my personal use) some interesting material on Russian web sites. And all the diagrams and values were all CORECT the first time around – no “misprints” – just good stuff available for all (who understand a bit of Russian) to use. Results are far better than anything I tried so far.
However, I had to spend time to source the parts, make the PCB, assemble everything, which I enjoyed (the “assemble everything” part).
Best Regards,
Extreme_Boky
Best Regards,
Extreme_Boky
Gee, Lars......if we keep agreeing with each other, my ol' buddy Guido Tent is going to get suspicious. [joke]
Yeah, guess I really need to build one to see just how bad it is. Too bad I don't have one of Elso's for a lab reference! [yet another joke]
There, I have offended 2 friends in one post. Only Phred could do worse, assuming he had that many friends [3 in one post........he's on a roll today!]
Jocko
Jocko
Cocky?
Me, cocky?
7 days of sinbin?
(edit by moderators: no, just some severe editing)
Lars Clausen said:
Elso: I wouldn't be so cocky, if i was you... I mean about people doing measurements on your clocks ....
Me, cocky?
7 days of sinbin?
Is this is reference to you, or some guy who wants to try patenting a scheme where he takes the noise ("error") from a clock and feeds it back to itself to cancel out the noise?
Wonder what his response will be when he finds that it has been done before? And that no one is going to pay him royalties?
Jocko
Jocko
Jocko Homo said:Is this is reference to you, or some guy who wants to try patenting a scheme where he takes the noise ("error") from a clock and feeds it back to itself to cancel out the noise?
Hey, a balanced clock?
That's cocky.
Maybe Jocko could try to build a supersymmetrical one......go figure who'll get the royalties.....carlosfm said:Hey, a balanced clock?
That's cocky.
balanced Clock
That's old news:
http://www.diyaudio.com/forums/showthread.php?postid=25748#post25748
http://www.diyaudio.com/forums/showthread.php?postid=26141#post26141
That's cocky.
That's old news:
Yes, why not?Jocko Homo said:You are missing the point, Elso...........
....Are you going to make me build one and measure it just to prove my point?
- Digital Source
- Clock wars?: 'Superclock 3' vs. KBK's personal design
