Hi evry budy
can you help me
I do not have access to T106-2 CORE
I have only atx core yelow- white or EI33
Can you guide me how to weld a wire
Can you guide me how to create GAPE IN THE CORE
can you help me
D
Deleted member 148505
I see gain of D200 is small.
I want to change it. How do I. Can you help me.
Thanks!!!
Thanks!!!
There is some mistakes...
Thanks!!!
Use preamp from post #661
Thanks so much!
I want to ask more. I use K2611 mosfet, but Rg = 47r ==> it doesn't work. When I change Rg = 560R ==> It work, But sound is no good. What the matter??
Thanks so much!
Use IRF640N instead 2SK2611
Good Morning.
I would like to use this project (D200) in my home theater.
Could you send me the electric schematic in my email (luizcpimenta@gmail.com)?
Thanks for listening.
Using the Google Translate
Good Morning.
D200
hi sir is there a PCB shares this SMPS on post #521 i have a lot of damaged ATX's
thanks
sam
Class D amp from Mackie active speaker.
Hello sir .What is the model number of the diagram
i'm not understand, IR2110 gnd pins (2) and 74hc00 gnd pin (7) is referend to negative rail? why is not connected to ground?
- Class D
- Class D Amp with LM566, LM393 and 2XIRF530
