Thanks to all for your help,now i going to someone with a laser printer and build this thing,but does it work at +-25v for a test
then im not going to test it at 25v,im going t jump directly to building a smps for about 80v since i thought 90 is to much and too many modifications have to be done
But put a light bulb in series with the mains in so that u dont end up with a charred amp and a charred smps if all goes wrong.
I have been always doing this with mains powered device,but i didnt think it will work with a smpsBut put a light bulb in series with the mains in so that u dont end up with a charred amp and a charred smps if all goes wrong.
It works with all mains powered devices, if the amp draws excessive current, the mains voltage at the smps will drop and possibly activate the uvlo of its pwm controller, but if the amp is fine, the bulb will be dim or completely off, just as it would with a linear psu.
interesting, i have found the ir2153 chip and a lot of people are using it for smpsus,just hae to find the right schematicIt works with all mains powered devices, if the amp draws excessive current, the mains voltage at the smps will drop and possibly activate the uvlo of its pwm controller, but if the amp is fine, the bulb will be dim or completely off, just as it would with a linear psu.
Use schematic from post #10 in this thread with 2 ATX transformers without rewinding.
Thats only 50v,how can i up the voltage,but thanks anywaysUse schematic from post #10 in this thread with 2 ATX transformers without rewinding.
sir abetir, for pcb etching in any weather, i'm diluting with Clorox the ferric chloride for faster process.
regards,
freestyle
Thank you for the tip Freestyle, 😉
Here's my D200v2 build, it still needs a few parts to make it complete....🙂
make some space for heatsink to be mount at mosfet.
p/s - i did run +- 45 vdc for irf540N no problem with full discrete ucd version.
smAll update: there were some misakes but they all have been repaired,tomorow i will be etching.
I have set a deadline for this project 6 june 2013,untill the i hope to have it done and working.If i dont have it built until then no big deal,its not an actual deadline,its just i time i have set for myself to motivate me
It was done on a copy machine,on smooth paper,and as my first pcb and amp ever,i will try and etch it tomorowBleh! Looks like KRAP! sorry.
H! Azmi,
Good to see you back..🙂 The Fets will be mounted under the board, I have here an old flat heatsink used for TO-3 outputs. I'll have to cut it though coz it's huge....😀
Regards!
- Class D
- Class D Amp with LM566, LM393 and 2XIRF530
