CD-PRO2 Module
It's from Taiwan.I like this kit so much,only 699 USD.
I will add a new Pure-Clock board to modify it.
Re: CD-PRO2 Module
Is there an english language website you could post? I too am interested in these kits.
Anthony
YENFU said:It's from Taiwan.I like this kit so much,only 699 USD.
Anthony
Pure Clock here!
I have got the pictures!
Pure Clock,TCXO with only 1ppm tolerance.This will help to reduce jitter of CD-PRO2 module.
I was looking through the manuals and the kit seems very well thought out and considering what's included, it's a real bargain (comparing for instance to what you are getting from Nico at not that much lower price).
If not for the fact that I already have 2 CD-Pro transports to play with (and recently bought ML31.5), I would be surely getting this one 😉
If I have any suggestions for improvement, maybe a plate that covers the display board section when the door is open.
a plate cover the CD-PRO2M module
I got the pictures from the website,the kit was assembled by Mr.Yang.
The plate was made by him,all DIY,looks fine!
But I won't do this in my CD transport.I like to see the words 'CD-PRO' when the door is open.I also like to see the mechanical structure inside,just like the traditional watch.
Re: a plate cover the CD-PRO2M module
Is it possible to have more information on this kit?
Is it still available? with 699$ what you got? any english link?
thanks
Giorgio
thanks
Giorgio
"covers the display board section when the door is open."
Ken: Thanks for the suggestion, Peter. We are thinking about making two of the support columns thinner, and put the board between the columns. But as of right now, the kit is provided with an acrylic cover to cover up the display board.
Regards,
Ken
Regards,
Ken
REAL 1PPM?
I also doubt about the spec. of 1ppm.The crystal is specially ordered from Japan.I guess the 1ppm spec. should be based on some special conditions.
But if the pure-clock could enhance the orginal CD-PRO2M module,it's worthy.
(jwb:your KMA-160 reverse engineering is amazing!)
Re: REAL 1PPM?
I don't doubt 1ppm, but I do doubt that it helps the sound. 1ppm is a specification for satellites, not for CD players. 1ppm simply means that the clock will have the same mean frequency in 20 years as it does today, but it tells you nothing about the relationship of two consecutive clock edges (jitter, phase noise, etc). Similarly, temperature control helps stability at very low frequencies, but is pointless at audio frequencies.
The mechanical suspension of the clock is also suspicious. What's the resonant frequency?
YENFU said:I also doubt about the spec. of 1ppm.The crystal is specially ordered from Japan.I guess the 1ppm spec. should be based on some special conditions.
Here is a really dumb question, but my ability to humiliate myself in public never surprises me. 🙂
Could you isolate any noise from an oscilator circuit by opto-coupling the output of the clock to the input of the device being reclocked?
Anthony
Anthony
Would someone please explain why the firmware for a fully loaded CD Player is so b****y difficult?! I'm onto Shuffle mode after completing typing in track numbers from a remote and next is rollover remote commands (volume / fast forward)...
Coulomb:
Also at the risk of embarrassing myself, I would guess not since I don't think Optoisolators can run at 16MHz...But that is just a guess. I was on a website for a clock (Can't remember which) yesterday, and the clock signal was said to be very impressive, yet it had ringing all over it. Presumably these clock designers are battling to find fast enough components. Elso / Guido?
Coulomb:
damping
I think no one have the ability to control everything which will hurt the sound quality.Using the Pure Clock only help us to get a better clock than BEFORE.
We still have a lot things to do.But we do try to improve the factor.(In fact.I do not install the pure clock in my CD-PRO2 transport now.)
The suspension column could fill in some damping material,such as oil.The resonat frequency will depend on the damping ratio.For me,this will be an interesting game.....IT'S DIY!
Hi BrianGT
I just joined the Forum yesterday.
I wonder whether its still not too late to add
myself to the list for one set of boards/chips.
TS
TS
hello brian
do you have a circuit diagram for your cdpro/display controller unit?
look forward to hearing from you
thanks
bill
thanks
bill
billr said:hello brian
thanks
bill
From Brian's website.
http://www.briangt.com/gallery/cdpro2-pcb
- Digital Source
- CDPRO2 Group Project (open source project)
