Cascode Output Stages
OK, what I have in mind is a hybrid amplifier in just two blocks.
What possibilities do we have for a very basic bridge output topology?
Balance is important, things like complementary structure not.
Anyone, please.
Hannes, start working on the problem...
Circlotron ;-)
- Klaus
pietjers said:
Bob.
I have never measured its distortion nor wondered what it would be. Simply because I know that the tube front-end has decent distortion figures and the output stage has very low distortion. Add the two and you have the total distortion.
I have learned from my experience that often measured performance has little to do with the sound quality of the final product. The real truth of high –end performance lies in other area’s than distortion figures. In most cases feedback does more harm than good.
Would love to hear more comments on the output stage idea I posted in post #30?
Peter
I like the output stage you posted.
You don't "KNOW" that an output stage has very low distortion until you've measured it. If you just assume that any old emitter follower output stage has very low distortion you are being very naive. This has nothing to do with your assertion that there is often discrepency between perceived sound quality and what is measured.
BTW, you would be amazed at what you see when you propoerly and thoroughly measure an amplifier. Most people don't properly and thoroughly measure an amplifier, and this is part of the problem (but certainly not all of the problem).
Bob
Peter,
Hhm, just a feeling from the stomach, so to say... I would perhaps rearrange the cascoding more horizontally than vertically. That is, each stage cascoded with the corresponding cascode transistors, not with the complete stage as a whole. Like cascoding predrivers with predrivers, drivers with drivers and outputs with outputs. This would shift the working conditions (and the timings issues) a bit (and would save two resitors). Hard to say if it would make things better or worse or maybe it's just insignificant...
@jcx: excellent Hawksford paper you linked to, thanks (I thought I had them all -- the relevant ones to amp design --, but obviously I missed this one).
- Klaus
pietjers said:
Emitter follower output stages for example, have very little distortion figures. And from my experience can have an output impedance as low as 25mOhm (5 output devices in parallel) without any global feedback. So why would one use feedback for this stage?
I've tried that once, it sounded very "musical" at first but after a few hours listening, I realised that I've lost some accuracy in reproducing the sound of certain instruments.
André
I am playing with two types of cascoded output Designs for Headphone use however it is simple to upscale to what you need taking into account the Voltage limitations of the J-FETS used in the casscode current sources.
Type 1 is similar to what (Lumba Ogir) Purposed I did not use any emitter resistors on the Drivers and Pre-drivers and this works good. A constant current source (Not shown) As purposed in one of Mr Passes patents between the Collectors of the lower cascode transistors can be used to ensure glitch free start up but not required.
Type 2 is a more conventional cascode arrangement providing cascoding of the Drivers and pre-drivers to each other. this type is so far as shown proving to have intermittent stability issues, However when it is working it has both better sound and lower measured THD and IMD performance than type 1. Both Circuits show very low distortion and i use the type 1 as a standalone Line driver stage with no gain or overall feedback (I consider Emitter resistors local feedback and thus any circuit using them really can not claim totally feedback free) Pay close attention to the different locations of C8 in the Type 1 and type 2 designs as this location was chosen empirically to make stable. Has more benefit on type 1 topology than type 2 and i believe once the type 2 is made unconditionally stable C8 can be eliminated.
Bob,
I did a quick read of the part about distortion measurement on your web-site. It takes quite a lot of experience and specialized equipment to analyse the distortion behaviour of an amplifier stage. What can one do with only a function generator and an oscilloscope?
Klaus,
Thank you for your great idea!
I think this is what you had in mind.
By fotopeter
pietjers said:
Bob,
Klaus,
By fotopeter
I would put some resistors between the upper and lower cascode's for the pre-drivers and drivers you would be surprised at how quick this topology will oscillate without them.
a function generator, while not a low distortion oscillator can be used with a dual trace oscope to function very similar to a distortion analyzer. set the vertical mode to ADD, and the ch2 mode to INVERT. apply the amp output to ch1, and the amp input to ch2. input a sine wave from tthe function generator. switch the scope vertical mode to ch2 and adjust the gain for full screen deflection. then switch the vertical mode to ch1 and adjust for full deflection. now switch back to add mode and observe the distortion residual. it's not perfect because of the glitches in the function generator sine wave, but it's close
Thanks Philip, (nice stages you have there). A bigger difference seems to be that you derive the cascode voltages from the output. Maybe one could get away with lower/no cascode emitter resistors with a input derive topology (as they defeat part of the cascode action depending on standing/max current ratio in the predriver/driver)....
- Klaus
Peter, you might also want to look into a soundcard based measurement solution, besides the scope nulling trick as described by "the Uncle" -- or hardware variant (nulling circuit), or a distortion magnifier (a specialized notch filter) together with a good generator.
With a common soundcard (24bits, 96kHz or 192kHz) and generator/analyzer software you can get quite a lot of resolution and bandwith for the given investment cost. I can get some 90dB reliable range at least for HD and IMD measurents, at 40kHz bandwith (24/96 card). With specialized measurements one can go even lower. It's not as convenient to handle as a hardware setup and you can easily blow channels with overvoltage if you don't clamp/protect inputs plus there ar some other issues (grounding etc), but I feel it gives the best results for the money, especially when you build your own driver and probe adapter electronics for the various measurement tasks (differential probe/drive, current sensors etc).
- Klaus
- Klaus
The Right Mark Audio Software based system that is also free is intended to test sound cards however with some Creativity and research on this topic (Google) you can measure amplifiers and sutch providing an FFT plot of the Distortion picture. Right Mark Audio
PPL,
It’s funny how similar your designs and my design ideas (are planning to give them a try in real life) are. The fun is that I hadn’t opened the shortcut in your post #51 before I posted my second hand drawn schematic. Saw it after posting when I was re reading the last posts.
I have an old Tektronics AA501 Distortion Analyser plug in. But the pushbutton switches are quite bad and not easy to get okay with contact cleaner. This analyser has a function output showing filtered distortion. But it’s very important to have a low distortion generator because normal generators have so much distortion that it will dominate the measurement. Must have also a Tek low distortion generator somewhere……., will perform a search soon.
Most difficult part will probably be to get everything stable!! I have built already the inner part of the cascode (the triple darlington part) and the only way to get it really stable is be means of the resistor at the input. From 2k and up it’s stable. Below 2k and especially below 1k the circuit starts to oscillate. I have tried about everything one can think of to control HF stability, but always the input resistor turned out to be the best and most effective solution.
What I tried (al the time with a square wave signal of a few V and a frequency of about 200kHz at the input to be able to closely observe ringing and oscillation behaviour):
• Adding base stoppers. Did not really improve stability. These resistors are only effective in the VHF region I think. The drawback of base stoppers (especially at the output devices) is that the output impedance of the circuit rises (want to use it without feedback).
• Adding capacitors from the base of the pre-drivers, drivers and output devices to supply voltage (tried it one by one). Found that their values are quite critical. Too small, little or no improvement. To big => instability. When about optimal still certain circumstances where the idling current starts to quickly run away for unknown reasons.
• Adding small capacitors from input to ground is a little playing with fire. Can also easily cause instability.
• Adding a small capacitor from output to input. Didn’t add much stability either. Perhaps I should have added a series resistor with the capacitor here.
But however I will try to get it up and running!
If you have suggestions, please let me know. I have already heard the suggestion to add resistors between the upper and lower half of the cascode, so I have added those.
Peter
what does yout input/VAS stage look like? i've found that if the input and VAS stages are too fast for the output stage, the design is uncontrollably unstable. also a triple darlington can be a difficult beast to tame. miller capacitance is junction capacitance multiplied by beta. so let's say your individual transistor betas are something typical like this:
predriver 200
driver 100
output 75
that's a total beta of:
200x100x75=1,500,000 !!!!!
so whatever junction capacitances you have, mainly the output devices, gets multiplied by one and a half million, and output device Cbco is about 100pf on average, some higher, some lower. a juncyion capacitance of 100pf in the output stage becomes a miller capacitance of 150uf with that kind of beta multiplication.
