Can someone send to me the Elso's latest clock schematics (version6)? :)
Kwak Clock 6
Here's my slightly modified Kwak Clock 6.
I have used a double sided PCB with the top as the ground layer. The PSU is included. Preregulation is done with LM regulators and i used soft recovery diodes for the two bridges.
jUST curious how the ver 7 clock works? How does it compare to the tent clocks?
My experience with two built kwak 7 clocks and one XO tent clock:
I had in my NAD 541i a (bad) implementation from a single supply Kwak clock 7. Today, I just removed the ferrite beads supplying the clock part and inserted a 8pin socket, the ferrite bead delivered with a tent XO, a 0.1uF cap and the XO itself.
The result is really good, the quality of this player is now better than my tweaked NAD510, including a good working kwak 7 single supply. Before was no remarkable difference! More details but some kind of softer than the other player. Lovely!
My conclusion is: Maybe, the kwak clock is working fine, when perfectly implemented AND measured. This means having adequate RF- and electronic knowledge and measuring equipment.
Otherwise, the result could be unpredictable 🙂
When using the XO canned module, just add a fine psu, a correct and short connection to the player and you can be sure the result is worth the money and time!
Franz
IMHO, Kwak Clock 7 must be supplied from a symmetrical ps, as this allows for adjusting symmetry of the output square waveform. I' m not a digital expert, but, to my understanding, this must be beneficial for the clock performance.
Just my 2p.
You see, this is exactly my problem, not having the adequate measuring equipment: for example my scope (old Heathkit OS2) is O.K. for audio purposes, not for frequencies above 100kHz.
So, I cannot test, if my clock is working well or not!
Elso recommended me to use a single supply in the NAD541i, as there is no symmetrical voltage available.
With the XO tent clock, I dont have such questions and problems to solve.
Easy!
Franz
