Bybee Fraud Protection
BQPs remind me of a SF short story, where a magician kept his cave cool by placing a screen at the entrance that let only fast moving air molecules out and slow moving ones in...
Actually, I think there's nothing in our science that says this is not possible - it just isn't possible without putting energy in the process (which then defeats the purpose).
Jan
As long as no-one in the room knows which amp is which on switching, it absolutely is double blind. Analogously, I may know that Amp A has a source impedance of 3 ohms, and amps B and C have source impedances of less than 0.1 ohm, and the loudspeaker has a dip to 2 ohms in the midrange, but that doesn't change the question of whether I can distinguish them in a DBT. This was stuff that was important to do 35 years ago to establish what was and wasn't audible in amp designs. Nowadays, we know quite well what people can and can't hear, so these kinds of tests are just sideshows, but there was an actual debate back in the 70s and 80s that had to be resolved.
I call slight foul as Krueger has admitted they knew the D120 misbehaved on the test speakers before they assembled the test.
True, but alternatively, this forum is knee deep in people maintaining they hear a difference that magically disappears in a test.
This was a test that confirmed DB what they heard sighted. Nothing wrong with that I believe - on the contrary, that is how it should be done.
Jan
Ah, that was my confusion. If the test had been titled 'can you hear a fault we have all heard before in blind testing' I would have not raised an eyebrow. It was because they said ' can you hear the difference between 3 amplifiers' when they knew full well what to listen for that made me think they had too much information.
As an Editor, I can confirm that article titles serve the dual purpose of a) describing the article content, and b) attracting readers.
Sometimes b) wins out over a) - I agree that in this case the title could have been more accurate.
Jan
Yes, that's the easy approach: simply stress the amplifier, and system with volume and the right recordings until the flaws of a particular unit, and configuration become very obvious, then the characteristic signatures of misbehaviour can be followed back and identified in normal playback situations. If a blind testing setup doesn't allow one to put the units under enough pressure to make them misbehave then the chances are very high that differences won't be heard.
I always find it amazing that differences that "are not subtle, the difference was like night and day, even my wife and kids noticed the difference" suddenly disappear when a DBT is carried out.....
Cue usual excuses from the GEB, true believers etc....
