Burning Amp 2024!
A bit more info on the NC-434....aka "The Cube" and speaker camp.
1. All materials to have a working set of speakers will be provided, glue, wire, crimp connections/etc...
2. The enclosure is a V-fold style assembly, so the 4 sides are taped, glue applied and then folded up. Front/back provide plenty of support once the glue dries so there's no need for screws/lock miters any of that jazz.
3. Should be no need for power tools, I've pre-drilled all pilot holes, milled all openings, drilled holes for binding posts etc. This should be glue, wire, assemble.
4. I'll be helping out with the entire speaker camp...so for those folks putting these speakers together you can consider it quite a few hours of my undivided attention to answer questions about the speakers, other speakers, loudspeaker design or other such things. That is, unless I get hungry and distracted, run short of caffeine and distracted or just otherwise distracted.
I'll do my best, but if there's a fluffy kitty cat, no promises. Or Brunello. Either one.
