Building an F5 Turbo v2 (in-Progress)
Well I finally have gotten a new set of output Fets, and the time to get back into this project.
The short story is that the compensation cap from gate to output (marked as C2 on the output boards, but marked as C3 and C4 on the V3 schematic) need to be used. 1000pF is working well.
Also the gate resistors have been increased to 680ohm. These two changes have seemed to keep it stable. Hooray! 🙂
Only one channel up and going right now, the other will be done tomorrow. If everything behaves, I will hopefully have some simple power measurements.
A few shots of the bench -
The Front-end board is mounted on the DIY-friendly base because it fits.
Yes, it looks like an explosion at a spaghetti factory - and this is only with one channel... Now I will be the first to mention that I haven't loomed anything together yet, and that will help a bit... but the penality of having the flexibility of the seperate FE board is all the extra wires. 🙂
Reactions: gaborbela
they need to be used in V2 ? or is that only if theres a stability problem, personal id rather be safe than sorry so perhaps i should follow in your footstep(s).
So yes, 6L6, you say that your amp was blowing outputs because of these oscillations without this cap? I am interested, cause I am planning on dropping in two extra pairs in my F5Tv2. The question if i too need this cap or not 🙂
If I get a chance, I am gonna hook up the output boards, such that I have 4 output pairs running off single FE board. This will be with standard 47R gate resistors and no cap. fun times.
I can do it anytime now, I just want to modify mounting technic on my 5U chassis, so I will be able do swap amps in no time. It requires some metal work and sanding, just being lazy 🙂
Indeed, thats why I do not want to mount them on the sink. They will be too close to each other and to the end on the sink(there are two per side). I will mount them on 10mm aluminum bar first and then all these on the sinks. It will help to spread the heat, but I have to prepare surfaces so they make a perfect contact along all the bars.
How hot do those PSU diodes get out of interest ?
i think ill add the C3, C4 as well as C1, C2. do they have to be bi-polar ?
just a guess maybe wire length is making your amp more susceptible to oscillations.
Btw out of interest which type of caps are preferred by audio freaks ?
10Deg F above ambient. Which is to say barely warm to the touch.
I think ill add the C3, C4
I strongly suggest bigger gate resistors as well.
just a guess maybe wire length is making your amp more susceptible to oscillations ?
Perhaps, but the original test rig had much shorter wire links.
New stock of the proper value and voltage rating.
I have had very good luck with the Panasonic T-HA series, as well as similar ones from Nichicon and Rubycon.
It does make sense to increase them gate resistors a bit as they are increased in v3
680ohm tho thats quite a lot more ?
caps, the Nichicon and Elna i have liked. Now all is left is to find the best Sill Pads on RS electronics site.
Thanks for your help 🙂
What kind of matching needed for OT ?
Hi All,
I am seriously following all the Turbo threads but could not find any info on how crucial the matching both between the paralleled N and P is (ok, the closer the better I guess, but...) , and more important if the N should be matched to the P which is more time consuming and last but not least far more costly.
I'd appreciate any help on this matter.
Max
