Building an F5 Turbo v2 (in-Progress)
The 100W incandescent light bulb goes in series on the live lead of a powercord. It's a resistor this way, and if there is a big current draw, it will limit the current by lighting up, which also indicates that there is a problem.
6L6, would you be so kind to post a link(mouser/digikey) on these pink silpads you use, please? I can't find them in this(big) size... :-( I use aluminum oxide and I do not like the result, the transistor is noticeably hotter than the sink next to it. Maybe, you can even measure this temperature difference? Thanks!
They are TO-220 but size is: 25.40mm x 19.05mm, the same as yours, 6L6.
Regarding thickness:
SP900 has 1.6 W/(mK) @ .23mm thickness
SP2000 has 3.5 W/(mK) @ .38mm thickness
So, Therm cond./pad: SP900 0.37 vs SP2000 1.3 in whatever units 🙂
oh. i've missed this tread🙂 6L6 you will reach the chassis max before the amp's max🙂
with +/-32V and 1.9A bias(standar V2) thats about what that chassis can handle without external cooling of some sort.
for +/-45V+ even a monoblock will have broblems when you bias it up to "full" power.
I've only just received (in todays mail) some different parts to try again. There is a place for a compensation cap on the output boards, and I needed to get some of those to try. I am also going to a much bigger value gatestopper.
There is one brand of Thermally conductive pad that significantly outperforms 1thou mica.
So far I have not seen any Members posting details of any competitor product that can match Keratherm's Kerafol 86/83.
If the others don't catch up quickly, they can only go broke.
Some experience about thermal pads:
we discussed earlier these two:
To not be speculative I bought two of them and tried. SP2000 are much better pads. I do not trust my thermocouple from DMM in terms of super accuracy, but with SP2000 TO-247 case of F5 is about 5C cooler.
