Building an F5 Turbo v2 (in-Progress)
Mallard,
On the current store boards the pots operate in the same direction. i.e. I rotated the rightmost pot so that they both zero anticlockwise (or clockwise, can't remember and I'm away from home at the moment so I don't have access to the drawings).
That is not fully true! When I measure on my pcb TP1-TP2 and TP3-TP4 I have to rotate the pots in different way to get on both TP the lowest (zero) resistance. yes you are right the pots are mounted in the same direction but electrically they behave oppositional.
biasing the F5T
Now I started to bias the 1st channel, up to now everything behaves as expected. I can increase the voltage drop over the source resistors and the heatsinks getting warm.
What I don't understood is: beside the temperature on the HS how do I recognize that I can't go further with the voltage drop? In other words how will I find that point short before the diodes start conducting?
Thanks in advance for your help!
when the diodes start conducting you will see the voltagedrop run away. you must be very carefull. and turn it back when you hit that point. if you get to that point at all before your heatsinks are too hot. or just calculate when they start conducting. and leave the voltage drop a far bit lower.
Thanks AudioSan, when you say "far bit lower" what do you mean by that? How many mV lower...roughly?
ohh man... with open chassis, 680mOhm resistors I'm at 380mV voltage drop.
Is it enough? I've not seen the diodes start conductiong yet. Temperature is really warm but not that warm that I can't touch it for a minute...
When I calculate correctly 380mV drop gives a class A peak power of ~200W, correct?
bias problem?
I might have a problem on the left channel to setup the correct bias.
Up to now I was not able to get both p-channel and n-channel to similar values.
After heating up I still have a gap of ~12mV between n and p channel.
I didn't have this problem with the other channel, that one was pretty much equal.
What could cause such a discrepance? Is there anything I can do about it?
Stable bias
Just a question for my understanding:
In order to get a stable bias and DC offset is it recommended to connect a B1 buffer preamp (no connection to CD player or so)?
I tried it and from what I can say all measurements are more stable and fluctuating much less whereby the DC offset was increased in comparison to no B1 connected.
Any suggestions?
