Building a Pearl 2
Good Morning,
The Pearl pre-amp sounds great now with my Lx-mini active crossover. The bass frequencies are being boosted by the Pearl 2. I have tried adjusting the input resistors without luck. Any ideas on where to look if the bass frequencies are being boosted/high frequencies are being attenuated? Would the 5pF cap at C9 be a suspect? Does anyone have a full simulation file for the Pearl 2 that I could play with?
  • Pearl_II.asc
    Pearl_II.asc
I picked up a FocusRite 2i4 Gen 2 just a short while ago and connected it to the output of my Pearl 2 build. Before I go digging too far into things, is this a somewhat "normal" noise profile from the Pearl 2? This seems a bit high to me, especially in the 10Hz - 100Hz range (right channel is red, left channel is green). Seems like there is some difference between the two boards that I'm trying to track down. This graph is from the "max hold" setting of the software.
Both traces are from an outboard DC PSU connected by a 5-ft umbilical cord. I wanted to compare inboard vs outboard PSU configurations and noise performance.
I have seen posts regarding the possibility of an “overload” to Pearl 2 from high-output MM cartridges, as well as posts saying that shouldn’t happen. After experiencing some unnatural sounds during loud passages with my (possibly aging) Ortofon 2M Red (5.5 mV), I bought a Grado Opus3 low-output cart (1.0 mV). I just decided that given the gain from a standard Pearl 2, it was better to feed it a signal more in the range of an MC cart rather than fiddle with the Pearl 2 itself. (Yes, the cart is $275, but I was ready to upgrade anyway.) I have never since heard the same unpleasant sound. Just my experience. Very happy with the lineup now.
The Grado's, being moving iron, need a lower value input resistor for correct damping. I believe that their website suggests 10k.
I pointed out the possibility of overload. You can always reduce the gain of the output stage.
The umbilical is picking up the 60Hz mains "field" -- you could try shortening the power connection, and make sure that the chassis of the Pearl is connected to "earth" ground.
Thanks, I hadn’t noticed that. I’ll try 10K ohms and listen. I foresee moving to MC cartridges eventually and just decided to keep the output gain unchanged. Maybe I’ll add a resistance switch for MC levels when I try the 10K value.
Thanks for insight and thread link! I was able to reduce the 60Hz-induced noise (was clearly seeing odd harmonics of AC hum: 60Hz primary, 180Hz, and 300Hz) by simply re-arranging the AC wires with respect to the DC umbilical. This lowered the noise floor to about -105dB across the spectrum. Still seeing about 5-10dB more noise in one channel than the other. I need to double check my wiring and solder joints between the boards.
It's a total system gain issue. The only gain you have will be in the Pearl, none in the crossover, which is all buffer, and the gain of the power amplifier. (The volume on the Elekit is just an input attenuator.)
It might work, particularly if you have very efficient speakers, and it's worth a try. The crossover input impedance won't be a problem.
But I wouldn't do it without a linestage...
