Build This MoFo!
Thank's for the compliments.
Heatsinks are from Conrad MF350-151.5,Overkill as they barely get warm but who knows what "EVIL" plan Michael has in store for MO-FO Mk2.
Maybe a couple of these critters pictured.
And a shot with the lids on.
Steve.
Very nice build! I was thinking you were constructing these in the "Classic DIY" style - that of over-engineering! I'm also a HUGE fan of wooden chassis - I like to make stuff look more like wooden furniture that can blend into the decor a bit. I see you've also used my favorite router bit - a 1/2 roundover. I use that bit on just about every project I make...
Newb question since I’ve never built a SS amp from scratch. How does one determine the correct size of heatsink to use? I’d like to give this amp a go, but am unsure how to determine size heatsink to get for either the 19v or 24v. I know there is a minimum recommendation in the write up, but I don’t know how that is determined.
Bloozestringer -
In the article Mike says, "The device dissipation will be pretty close to your power supply voltage times the idle current. So, for the 19V, 1.7A example, we need a heatsink that can dissipate 32 watts with no more than a 25C rise above ambient temperature. That’s .78C/W, which I consider to be the minimum figure. I will award bonus points if you use oversized heatsinks. A lot of beginner projects run into trouble because of inadequate heatsinking, and using big heatsinks just makes life easier."
So... in english, that means a fairly big heatsink. Also of note, the smaller the number in the heatsink temp/watt coefficient the better.
Were I to build them I'd use a 4U 300mm heatsink from hifi2000, as it's more than big enough and I have them sitting on my shelf. 🙂
This would work beautifully as you'd need at least 4" height to keep the choke in the chassis - http://www.heatsinkusa.com/10-080-wide-extruded-aluminum-heatsink/
As would this - http://www.heatsinkusa.com/8-000-wide-serrated-fin-extruded-aluminum-heatsink/
(And yes, you are reading that correctly, the 8" has a better rating than the 10", mainly because the fins are deeper. At a height more than 3" they are both more than enough for the job.)
You want a Max rise of 25C above ambient.
To give you an idea have a look at the attached file, you will see a list of available heatsink from the DIYaudio store along with the heatsink size and c/w coefficients. For a regular MoFo look for 0.6 c/w or below, ex 0.5 c/w
BR
Eric
Hi
I bought a 13 inch long heatsink (Wakefield 392) and a friend of mine cut it in 2 parts and then sand blasted them with micro glass. They look stunning IMHO and now I’d like to protect them with a thin coat of clear spray.
What brand and type would you recommend knowing that the heatsink will be at about 45C ? Pls recommend something you have tried and trust.
Attach is a pic.
Eric
Hi
Attach is a pic.
Eric
How will you apply the paint? I fear the shape will make very difficult to properly reach every area.
Have you thought about anodizing? It can be made natural color if you want to preserve it. Otherwise black will give you a marginally better heat transfer
I, too, have always heard that painting sinks is a bad idea as it greatly reduces the emissivity factor compared to black anodize. There is a nice table of emissivity factors that includes raw and anodized aluminum. I'm not quite sure what to make of the "aluminum paint" (highly variable at 0.27-0.67) and "paint" (0.96) entries in the table, though...
