Buffalo DAC (ESS Sabre 9008)
Re: Some VREF fun...
Russ White said:
Ok for you die hard tweakers out there. I will throw you a bone. :)
Here is one mod which I know will pay dividends.
Now you have a sub 100nv (I will have to measure it later but I know its quite low) noise voltage reference that is not connected to the digital supply in any way.
You still have the excellent PSRR of the LM4562 and milliohm output impedance.
Cheers!
Russ
Thanks Russ. Makes a lot of sense! Noise level from 30uV to 100nV 50db lower...
Russ White said:
Just to show I actually tried it and it works (and sounds really nice)...
Thanks Russ.
One more here. Done with 2SK170-GR as ccs.
Don't ask yet. I don't even know if it's working or not.
