Super! I hope it arrived safely and in good order. I suppose it will take some time before you hook it up to test it.
I highly recommend a 2A capable 12v PSU. When I use a “Watt-o-meter” wall plug power monitor it shows 14W draw. So 12v x 1A supply is only 12W and less than needed power so best to use at least 1.5A capable 12v supply.
Good luck!
Good luck!
Yes, everything is fine!
I have a MeanWell 12v 4.2A psu, so it should work.
Hook up will take some time, another week of crazy workload, then off on vacation until mid-august in Norway![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But next week I will find some time to design the chassis, so maybe the parts will arrive also mid-august.
Wow, it could be a funny autumn![Thumbs up (y) (y)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hi, Im new in class D building. I looked for RTX module
https://www.ghentaudio.com/products/rtx?VariantsId=10801
and found this one. Would you please help me out about that one your referring to.
Thanks.
Thanks.
It’s the subject of this thread. Look at post #1 as it has the details. You can get them here:
https://xrkaudio.etsy.com/listing/1474151499
The HyperSET buffer performs balanced or single ended to balanced and single ended output conversion with a tube buffer stage in between that can be bypassed for solid state operation. There is also available gains 0/6/14/20dB selectable with DIP switches. Max output from OPA1637 line drivers is 53Vpp in balanced output mode.
Hi FJEL,
you need the BTSB light https://www.etsy.com/at/listing/123...0844&click_sum=1347093b&ref=shop_home_recs_16
- Group Buys
- BTSB with Tube Buffer - HyperSET GB
