BTSB Buffer - SE/Bal to SE/Bal Buffer GB
The panel mount version uses OPA1637, so can drive 50mA - maybe 600ohm headphones and not too loud. The other version uses LME49724 which can drive 80mA I think so that may have worked a bit better.
You can easily give it a circuit for muscle to drive balanced headphones. A pair of PCA daughter boards can be connected to the outputs of the BTSB to drive a balanced channel. You would need 4. Building it is easy though. I have done this before and it’s pretty great sounding.
https://www.etsy.com/listing/715372...ck_sum=7d234796&ref=shop_home_active_28&sca=1
A pair of Yarra/M2X breakout boards can be used to hold the boards.
https://www.etsy.com/listing/103315...079&click_sum=001c87d2&ref=shop_home_active_8
https://www.diyaudio.com/community/threads/xrk971-pocket-class-a-headamp-gb.302859/post-5121677
I will soon receive my BTSB SMT v1.2 pcb. Been reading through this thread, and I'm wondering: Do this pcb need any modifications ?
Hi Folks,
I am sorry to tell you this, but there is an error on the BTSB board v1.1 and v1.2 and the SMT boards. When I built the verification board, I failed to test the SE outputs - I have been told by a member who contacted Jhofland and together, they determined that the phase on on the J36 connection is flipped. Having just ordered a new set of boards (now with this error), I will have to get a new set ordered and send out replacements to everyone who has already bought one. If you have not started populating them, you can wait for the new ones. Or if you have no need for SE out, you can go on as usual. There is a workaround by crossing some resistor legs on the TH board. The SMT board is not so easy as it requires cutting a trace and adding a jumper.
J.R
Received the Pcb from XRK and the parts from Digikey today 🙂
Time to do some SMD soldering !
Why not ? Better tolerance on the resistors is one good reason. 1% against 0.5% or less for some of them.
Another thing: Where do you find the op-amps in a DIL8 package ? They are all in a soic8 package. So, better to do the whole thing with SMD's 🙂
