"Bigun's TGM8 with single Supply" Revisited
Dear Wahab,
For single driver Full range loudspeaker systems, the sweet spot is around 30 to 50 watts. 63 volt electrolytics are very easy to get. So, a single power supply of nominal ~50 volts, with Elec cap output will fill the place, provided the quality is good. So around 10 years back, I first posted "Bigun's TGM8 with single Supply". This type of retro design with readily available components also avoids output dc protection complications, if the switch ON transients can be avoided.
I am also using this thread to learn more about amplifiers and compensation niceties.
Thank you for your interest and contributions.
--Sarma.
  • Thank You
Reactions: gannaji
Will it be possible to change M1 - IRF510 to a BJT please? How much is the current of the CCS?
If you use a bipolar transistor there, it will affect the thermal stability because... The bipolar transistor in the current generator has a negative temperature gradient. Side transistors have their own thermal stability, so their gradient does not add up and does not affect the temperature characteristics; I am using IRF in a power current generator.
Dear Wahab,
--Sarma.
Ok, that s quite high powers here, if you want 30W this require about 50V sustained supply and a 43V AC transformer, when idling there will be about 60V, so that s a little too much for a 63V capacitor, personaly i did settle for lower powers in the 15-20W range for my everyday lateral FETs amp.
Also laterals require about 100mA bias for best perfs although lower values works as well, at 100mA that make roughly 10W idle power for two channels, better to use a toroidal transformer since its losses are much lower than a classical E or double C transformer, i use a 30V transformer and laterals are biaised at about 20-25mA.
Anyway good luck with your project, i ll take a look from time to time to see in which direction the ship is sailing.
  • Thank You
Reactions: gannaji
P-channel and N-channel laterals differ markedly in capacitance, with P-channel 50% more or so, although C9 should common them up at AC and hide this from the rest of the circuit - transconductance may differ a little too - so it is to be expected to see one device oscillate first if stability is borderline. That suggests it shouldn't take much change to stabilize it. Or one of the FET models is just wrong(!)
Reactions: Hennady Kovalsky
Fets capacitances difference is not the culprit, all the NFB around the VAS enclose the output stage, there s about nothing that
is enclosed locally through C7, you could as well remove it, and going to 120R from 100R for R12 is just cosmetic, i made a lot
of sims for this kind of compensation, what you see in the simulator for global frequency and phase response is not the real thing.
The Gang amp as published in #43 has been entered into LTspice. There is heavy oscillation in the lower half of waveform.
I found a solution, you need to connect R12 (see attachment.) to the output of the amplifier and recalculate the values of the correction capacitors, see attachment.
Try making these changes, the amplifier quality parameters remain the same.
After the mod as in #56, the freq of oscillation changed.
We see that the generation at the lower half-wave has become noticeably less, therefore the point is precisely in this correction circuit, namely in the choice of correction frequency. It is necessary to select (adjust) the capacitance ratings for your version of the transistor model.
Try increasing the 22pF capacitance to 47pF, and decreasing the 100pF capacitance to 47pF. My model shows an open loop gain of 106 dB, this is a large gain, and the unity gain frequency must be lower than the cutoff frequency of the output transistors. Because We have different models of output transistors, then such generation does not occur for me, and it is difficult for me to suggest a minimum value for these capacitors.
  • Thank You
Reactions: gannaji
Dear all,
I took time to try following my earlier procedure. Disconnected the TMC, adjusted C5 for good olg margins. Added TMC with C7 = 680p and R12 = 1k5. Adjusted the currents in outputs. The oscillation is gone. The simulation is to be checked with TMC terminated at various points. The files are attached below.
Over load recovery is not good.
