Do you know which parameter/s make these good for each duty?
What's your means?
Epcos B41505 show lowest ESR and high rip current more than any snap-in caps.
This is good choice for power supply, make power supply more perfectly.
And long life.
Low ESR/high rip current caps and ultrafast diodes for power supply. I think they're good. The cost is not to high, like high capacity caps and general diodes.
The Epcos are excellent, but you won't find them 10,000 or 12,000uF / 63V rated (and higher) for Power Supplies...What's your means?Do you know which parameter/s make these good for each duty?
And long life.
For this purpose probably this Vishay BC would do the job better than many others, including NichikonKZ/KG. Yes, they are "screw terminal" and they have that pretty ugly blue dressing, but who cares?
Another choice (snap in) for the Sikorels would be the Vishay BC 059 PLL-SI ...
It doesn't help that they also stopped manufacturing their niche high-value lines like Black Gates.
not sure they ever existed ... i think of them as proto adventure that went wrong, and thus had to be stopped
maybe that was a costly affair
were they not a forerunner of the new polymer technology
and never intended to be 'audiophile'
it just happened 'backwards'
looks more to me like the 'audiophile production' was a following desperate effort to cover the losses
"Epcos B41505 show lowest ESR and high rip current more than any snap-in caps."
Karl, that's why they do the B41554 SIKOREL series (125°C):
10.000 µF : 16V - 25V - 40V - 63V - 100V
15.000 µF : 16V - 25V - 40V - 63V - 100V
22.000 µF : 16V - 25V - 40V - 63V - 100V
33.000 µF : 16V - 25V - 40V - 63V - 100V
47.000 µF : 16V - 25V - 40V - 63V - ----
125° C seems perfect for class A.
and the B41550 / B41570 SIKOREL series (105 °C LL):
You just have to accept screw terminals which is anyway superior.
Of course there's much more. You asked for 10/12 mF / 63V and higher.
I have to admit for sentimental reasons I'd prefer a "Siemens" badge on
them and "Philips" on BC. Sadly that's history. However, I have some
older Siemens Sikorels that still measure fine, better than newer Mundorf
HC lytics.
If you can afford them - get Sikorels !!
Rubycon got into trouble because they were late in switching from Aluminium to Solid Polymer Electrolytics, which are now the mainstay of the commodity PC and digital equipment business. That business is now dominated by Sanyo, Nippon-Chemicon, Nichicon, and some Chinese and Taiwanese rivals. They also got killed in generic electrolytics by Panasonic, Elna, Nippon-Chemicon, Samxon, Samwha and others. Rubycon now has some polymer lines - but probably too little, too late.
Will not miss them except their High Q NX Black Gates.
Nice! These B41554 goes indeed good with class A or Mosfet driven circuits.Karl, that's why they do the B41554 SIKOREL series (125°C):
HC lytics.
And I've heard that F&T actually makes many of Mundorf electrolytics.
Thanks!
Thanks!
Hehe there is only one manufacturer off electrolytics i Europe.
Germany?Italy?Czech?Slovenia?Ukraine?Hehe there is only one manufacturer off electrolytics i Europe.
There are still other brands too.
The Rifas PEH169 are very VERY good. The only "problem" with them is that you can't place them with vents downwards because they seem to have a much higher proportion of electrolyte inside them compared to other capacitors...
Datasheet: http://www.it-tronics.de/Files/Datasheets/Capacitors/E-Caps/Rifa/PEH169.pdf
Germany .
Erlend, enlighten us.
Epcos, Krummer, Fischer & Tausche, BHC, Evox Rifa all from just one plant?
Don't know if BC (formerly Philips) went to far east. Or did already most of
them go to China?
them go to China?
Startseite - FTCap Fischer & Tausche Capacitors Group
Vishay headquarters are in the US. They have plants almost everywhere in the World....
them go to China?
They made vast companies acquisition and therefore extra expertise from those engineers and stil are expanding a strong further acquisition policy.
Vishay - Company Info - About Vishay
Thank you both, Erlend and Karl.
Sadly no word what they make in Europe and in which country.
Sonderanfertigungen - FTCap Fischer & Tausche Capacitors Group
I don't know if they mean "lytics in Germany" and "foil caps in Switzerland" or whatever.
BTW, "Audio-capacitors":
Audio-Kondensatoren - FTCap Fischer & Tausche Capacitors Group
Guess, it's no that they look the same as Mundorf HC:
Serie GW -40°C ... +105°C (5000 h) - FTCap Fischer & Tausche Capacitors Group
Vishay has manufacturing plants in the Americas, Asia, Europe, and Israel, as well as sales offices worldwide.
Herstellung ausschließlich in Deutschland und in der Schweiz
maybe not 2 years ago, but I think all are fabricated is in India now
or at least the ones sold are, because they are cheaper
you may even be able to find the exact same cap at 2 different prices
the 'costly' one is 'old stock'
and new stock is the cheaper one
but basicly they may be the exact same cap
Vertriebspartner - FTCap Fischer & Tausche Capacitors Group
The Swiss division of Fischer & Tausche is Leclanché:
Homepage - LeClanché Homepage
Expect Mundorf MKP, KP and Supreme caps to be made there . . .
Unser Partner für Audio-Kondensatoren:
Weltweit Mundorf Köln
Sorry I do not know what caps they make in Germany.
- Design & Build
- Parts
- Best electrolytic capacitors
