[Nichicon KA] My prefered for the the time being. Seems like they add an extra octave in the bass . Soundstage is deep and detailed.
I'm wondering if that "extra octave" wasn't achieved through less midbass - so the lower bass becomes more prominent. The overall sound is pretty dry. But yes, it will occasionally surprise you with a flurry of lower notes that you never knew before to exist on your CD. OTOH the upper end could be more fluid.
Hello Diy'ers,
I've noticed your talk about magnetic leads on electrolytics in this thread and wonder if there is a sort of general guideline as to which capacitors has magnetic lead assemblies and which don't? Like "manufacturer this & this use magnetic leads whereas this & this manufacturer don't".
Has this been discussed somewhere?
Jesper
Jesper
The standard is ferro lead wires so copper wires today are an exception. This means in practice nearly all recent electrolytic caps have ferro wires. You will have to use so-called audio types to have tinned copper lead wires and even then you will have to be cautious as some manufacturers don't even mention the choice of materials in the data sheet. I experienced the use of aluminium lead wires too but that is better than ferro...
Industrial caps have ferro wires in 99% of the cases. Copper is an expensive material these days. I fought it but lost the battle with ferro caps and use caps with ferro wires as they can be quite good (depending on brand and type).
4.7 millifarad cap?
Hi there!
Taking advantage of this, I'd like to ask if the electrolytic below is indeed 4.7 mF (milli Farad). It's found inside some synth tuners and also what part it should supply or filter or eventually the purpose of such particular cap.
Thanks!
Hi there!
Thanks!
Memory 4.700.000 uf I think.
Back-up memory. OK!
Its they won't pass stress tests with pure copper leads. Think suitability for automotive, machinery, aircraft, etc.
@ jean-paul:
Thanks for the feedback ;-)
Jesper
Jesper
4700 uF, actually. It's a bit low for memory, but maybe some standby settings could be kept for a few minutes.
The super-caps used for memory generally have values in Farads, not mF.
Yes, you're right.4700 uF, actually. It's a bit low for memory, but maybe some standby settings could be kept for a few minutes.
But being labeled differently (4.7 mF instead of 4700uF) and having this "SB" series mark on could also mean it was designed for backup memory os something similar. Otherwise one could just put a normal 4700uF 10V (or 6800uF 10V) and the work is done?
maybe mF mean memory farads ...😀
from where Im sitting memory caps are only max 5.5V
and called double layer caps
and a very big sized cap like that one, with low voltage, must be be a memory cap with farad capacity
actually it appears to be a 5.5V, so....
Ok, tinitus and folks! Thanks!
Yes, it's double layer cap and the 5.5V, thus backup memory cap.
1 femto is small, but a small what?Have seen 1 f much smaller than the 4,7 mf !!!!???
And what is a milli-femto?
EPCOS B41505
Has anyone listened to this model, for main filtering? (not to be confused with the Sikorel model)
I found it reasonably priced at Mouser for what the spec sheet calls out; incredible ripple and ESR numbers.
But not being a big numbers guy...
EPCOS B41505
Very interesting. According to its DS, the 3300uF 100V presents 7.7A of RC capability... Putting 4x of those in parallel and you have a nice 13200uF per rail for a 12000uF replacement...
http://uk.farnell.com/epcos/b41505a9338m000/cap-alum-elect-3300uf-100v-can/dp/2283923
EPCOS B41505
So am I going to have to try a set of the B41550 in my power supply without any internet hand holding?
This is taking way back to a time when I had to do a lot more thinking for myself!
Great thread by the way...
Will report back here on the Epcos later.
What values are you using? I'm interested also in this series! 🙂So am I going to have to try a set of the B41550 in my power supply without any internet hand holding?
- Design & Build
- Parts
- Best electrolytic capacitors
