Unfortunately this thread (according to the OP) is about signal relays, rated for far smaller currents. You seem to be looking for a thread about output relays.Any views on the BEST audio relays for line level signal switching?.....
Bonsai,
Silver and Palladium is physically a better material for relays..the ASX type is perfect for Phono preamps . ASX ( Palladium) and TXD ( Gold ) .
Sorry most links in German.
https://www.panasonic-electric-work..._x61_de_elektrotechnik_201108.pdf?type=target
https://www.panasonic-electric-works.com/cps/rde/xbcr/pewnew/fb_x61_de_09_2013.pdf?type=target
home - Konradin Verlag
http://media.digikey.com/pdf/Other ...her Doc/Small Signal Relay Techincal Info.pdf
Bonsai, look at SX (ASX) Panasonic datasheet:
Contact material Stationary contact: AgPd+Au clad Movable contact: AgPd
Nominal switching capacity: 10 mA 10 V DC (resistive load)
Max. switching power: 0.1 W (resistive load)
Max. switching voltage: 10 V DC
Max. switching current: 10 mA DC
Min. switching capacity (Reference value): 10 μA 1 mV DC
According to above data they should be better than AGN/AGNQ Panasonic. What is your opinion?
Janusz
Janusz
yes, they are obsolete for one thing, also the contact will only carry a max current of 10mA and 10VDC. The ratings are a little low for using this relay as output of the preamplifier and to me a little limiting as well as at the input.
I was looking at those for some of my projects but then I had a second when I had taken into full account their max ratings.
Conversely the Teledyne highlighted here at the beginning seems to be an interesting part although very expensive.
Does anybody here have any experience with that particular relay? I would wonder if anybody has auditioned it against other type either dry or wet relays type.
You wouldn't want them -- some have the incorporated transistor, various coil impedance. and not enough to go around.
Hi Jack - from an audio perspective, any disadvantage to using the TN version of the Teledyne? Seems like it would save me wiring up a few parts. Seems like there's a good supply of surplus parts available online.
Best Relay for Volume control (Audio Stepped Attenuator)
I am looking for the best relais for a volume control (audio attenuator) unit like this one:
Audio Volume Relay Attenuator with IR Control
or this one:
Apox Controls
Which of the in follow mentioned should I prefer
1) in order of best sound quality and
2) in order to the best price-quality ratio ?
OMRON G6S
http://omronfs.omron.com/en_US/ecb/products/pdf/en-g6s.pdf
in use at
Volume control
http://omronfs.omron.com/en_US/ecb/products/pdf/en-g6k.pdf
AXICOM D2n* Relay V23105
http://www.te.com/commerce/Document...rchrtrv&DocNm=108-98007&DocType=SS&DocLang=EN
Reed Relays Vs Standard Relays
HUIGANG HRS2 Series
http://www.farnell.com/datasheets/296895.pdf
Elesta SIS4
https://www.elesta-gmbh.com/files/sis4-sen.deutsch.pdf
https://www.elesta-gmbh.com/relais/relais-produkte.html
Pickering Series 110
http://www.pickeringrelay.com/pdfs/110-vertical-sil-reed-relays.pdf
http://www.pickeringrelay.com/products/single-line-sil-series-100-110/single-line-sil-series-110/
Panasonic TQ series
https://na.industrial.panasonic.com...al-relays/signal-relays/series/tq-relays/1203
Panasonic DS series
https://www.mouser.com/ds/2/315/mech_eng_ds-1075856.pdf
Panasonic SX Relays
https://www3.panasonic.biz/ac/e_download/control/relay/signal/catalog/discon2011e_sx.pdf
Panasonic TX Series
https://www.panasonic-electric-work...-ein-universell-einsetzbares-signalrelais.htm
https://www3.panasonic.biz/ac/e_download/control/relay/signal/catalog/mech_eng_txs.pdf
COTO Technology 2200 Series
https://cotorelay.com/wp-content/uploads/2014/08/2200_series_reed_relay_datasheet.pdf
COTO Technology 9814+9852
https://cotorelay.com/wp-content/uploads/2014/09/9814_series_reed_relay_datasheet.pdf
Teledyne 712
https://www.mouser.de/ProductDetail/Teledyne-Relays/712-12/?qs=O2qRfqcg9D/kZED68Zwing==
http://www.teledynerelays.com/Datasheets/712.pdf
http://relays.struthers-dunn.com/category/reed-relays
Struthers-Dunn
http://relays.struthers-dunn.com/Asset/131_Series August 2017.pdf
https://de.onlinecomponents.com/datasheet/w134mpcx2.aspx?p=12326166
General considerations
http://www.clare.com/home/pdfs.nsf/0/39D76825F4FE22E085256B03006E9F86/$file/an-145.pdf
http://www.aufzu.de/semi/cpclare.html
https://panasonicelectricworksuk.files.wordpress.com/2013/02/modern-relay-technology_smaller.pdf
https://media.digikey.com/pdf/Other...her Doc/Small Signal Relay Techincal Info.pdf
Best sounding signal level relay? post 30
Thank you very much for advices.
or this one:
Apox Controls
OMRON G6S
in use at
Volume control
HUIGANG HRS2 Series
Elesta SIS4
Panasonic TQ series
Panasonic DS series
Panasonic SX Relays
Panasonic TX Series
Teledyne 712
Struthers-Dunn
- Best Audio Relays
