I posted a request, just on its own, asking about a 'lights out' option. no replies ;(
I plan to do this myself; and have a remote control that enables/disables this.
Hi Linux,
I must have missed that post.. Lets see.. I'm no expert, but I imagine if the level is hi enough to trigger the input red LEDS, and you are not attenuating, adding gain or EQ anything on the DCX, then the signal will be the sam and still light up the output red LEDS too,, That's what I find anyway,, and I am confident that it's just "padding" on the DCX output LEDS and the actual signal has not reached 0dB or beyond..
I have analysed a lot of the FLACS that caused red lights and none of them are at 0dB or beyond.. And since I am not EQ'ing or adding gain, I am not worried that the output red LEDS are lighting up too.. If I was adding gain or EQ, then maybe grounds for concern..
If I am not adding any gain or EQ, then why would the signal be bigger on the outputs?? So if red lights on input, then I imagine red lights on output??
Ta
CM
If you are running sweeps, yes. But for music you shouldn't see many reds on the outputs.
That's going to depend on the music and where your crossover points are, of course.
I had suspected that the 5V supply is not all that bad. Sure, we can do better, but would you really hear it?
Pano, if not done yet, changing the genuine switched PSU +5v A1 & A2 (IIRC only for the analogic part of the DAC) for a linear one, is something that you have to do. Do a search, everybody agrees that the improvement is huge, in clarity, naturalness...Even a speaker guy like me can ear that. And it's not difficult thanks to the modular structure of the DCX.
hey murphy,
what I want to do is turn ALL lights off. this visually noisy box is distracting if its installed near your tv 😉 lights are great when you want to check something; otherwise, I prefer my stereo gear be visually quiet.
behringer clearly meant this to be used in an audio rack and not in a living room, but still, its useful in many settings. I just hate jumping leds that can't be disabled. amazing that B didn't give an all-lights-out mode; it would be simple at the software level. since we don't have software access, I want to find out if there is an acceptable hack to disable all lights (even lcd backlight). maybe all the panel lights could have their common lifted and the lcd can be dealt with simply by breaking the backlight connection on command. but I have not opened my boxes, yet, so I don't know what I'm in for in the quest for front panel darkness 😉
It has been discussed before, I belive on the Yahoo DCX2496 group.
I posted what to disable to extinguish the lights. Not straightforward as pushbuttons and LEDs are muxed on a buss and you can't disable the 5V as there's also a processor on the display board that needs to run.
jan didden
hey murphy,
what I want to do is turn ALL lights off. 😉
I get you now.. I thoug you were referring to red output LEDS... Ooppss..
Yes, that's what I want to do as well..
If I find out anything I will let you know..!
Ta
CM
jan didden
That's great news Jan!! i am a member of that group,, but alas,, I do not find it easy to navigate around that platform.. Could you possibly post something here? 🙂
btw: Isn't there going to be a mod offered by Ward to "bring back" input C for those using the 'Didden Active i/o'.. Any news on availability??
Cheers!
CM
[snip]btw: Isn't there going to be a mod offered by Ward to "bring back" input C for those using the 'Didden Active i/o'.. Any news on availability??
Cheers!
CM
I'll check and get back to you,
jan
A pretty walnut burl panel. 😀
OK, I'll give it a try. But you do know that the 5V and 3.3V supples are linear regulated, right? The 5V supples use the standard 7805 regulator and the 3.3V is derived from that. Of course those are fed from the switching supply.
Cheers!
CM
Pilgham just told me they have the PCB ready but need to do some final verification tests.
Maybe drop them an email to get notified when they are available.
jan
Right, but as they come from a couple of 7805, themselves seeing a common 8 V from the switch PSU, maybe it's the reason.
I forgot about the (so beautiful !) Janneman's boards, but for the french school it's just removing the regs and soldering here the output of the 317 circuits.
This is the simple mod that IMHO has such a big impact on the sound quality. As I did the same surgery for all the other tensions, I can attest that the sound changes are mostly then in the imaginary domain. Or said differently, after the long times it takes for finishing the job, the auditive memory is not trustworthy.
Anyway, about the idea of switching off all the led and screen display when listening seriously, it's not that futile, because (in standard config IIRC), the screen is powered by the same +/- 15 volts that's in use for the genuine Op amped output stage.
jan
Ok, thanks Jan, will do..
btw, I (finally) found the thread about disabling the LEDs on the Yahoo group, and have downloaded the pdf provided for this mod.. Is it ok to copy some commentary on here, and to attach the pdf ??
Ta
CM
Straightforward leds Off ? Put a panel on hinges.
I was also worried about burn-in. after years of having the same pattering going, lcd's do tend to have burn-in.
so, in 'all lights out' mode, I'd like even the lcd's to not be driven. backlights of course, would be off; but not even the lcd data would be active (or sent thru). ie, there would be a 'setup' mode and then a 'use it' mode. you should be able to swap between them easily. it annoys me when a vendor forces a disco light show on you and you have no way to disable it 😉 again, I know its a pro audio piece and the idea of lights-out is not a 1st level feature for their must-have list; but it sure is for home use, imho.
Linuxworks, the solution is on the yahoo DCX group.. I don't if I can paste the info on here,, but everything you need to know to achieve this is on there, including a pdf which shows the wiring procedures.. I haven't done it yet, but I will have a go pretty soon..
Ta
CM
It would be equally as easy for General Dynamics to put in a switch to turn off every instrument in a F16, but how useful would it then be as a fighter aircraft? 😀
True Pinkmouse,But even a blind man can tell when the sun is shining,lol.
The deq uses the 9 volts for the lcd ?correct?Could put a switch there like a momentary?
Thanks!
Thanks!
Ta
CM
Yes of course!
jan
Quite a lot RF EMI there inside the DCX, maybe a new PCB design for the "mother board" would be needed:
Signal from DAC's to I/O card
Unless you can't EMI shield the mother board then the only viable option to get a clean environment for the analog circuits is to use an optical digital (TOS/ADAT-) link outside of the rack box to external DAC's, right?
- Digital Line Level
- Behringer DCX2496 digital X-over
