both C104 and C105 are designated as Philips MKC
MKC is my personal favorit, it doesn't mean that it must be yours - put whatever you prefer
Ah,Is that yellow cap in the bag Phillips MKC?
Philips MKC 341 1uF 1.0 250V Chicklet Axial Audio Polycarbonate Capacitors, 2pcs | eBay
That's why it looks same colour.
see, you have right ones
previous boxes I bought were blue ones, last time I got yellow ones
so, color is irrelevant
Finished building the amp this morning.
Sound is so nice like clear stream.
????????????????????K - YouTube
Thank you ZM.
Thank you ZM.
ZM,
Yes, you were actually quite fast! I've had your boards since early summer! My plan after finishing my SE Aleph experiments on the NPXP platform, is to build the M2X with all daughterboards and make comparisons - I will pick one or two 'best' sounding from there.
The final M2 'iteration' will be your Babelfish M25 R.2 since it is your own buffer design + Cinemag CMOQ-4HPC + M2 output stage w/XA25 square law arrangement of output stage mosfets.
Should be a great comparison.
Best,
Anand.
Best,
Anand.
Derk means on paper?yes
that's good Drek
What I need to change If I swap MOSFETs?
not reallyAny drawbacks using 2sk1530/2sj201 instead IRFPs driving 4 Ohms loudspeakers?
polite interpretation of well known sentence "that's good ****"Derk means on paper?
meaning - those are good ones - having lesser capacitances (not so important here), slightly smaller xconductance ( important, but difference is not so big)
it is slightly possible that you'll need to alter some resistor value to fine tune Iq, but no biggie
inform if you have any trouble doing it
Your Mightyness, just started to collect the parts until the boards arrive, and have a short question: is it required to match the 240/9140? Further, can I use 9240 too?
Many thanks
Many thanks
no matching required
yes, you can use IRFP9240
though, it is known (ilimzn wrote that numerous times) that 240/9140 are somewhat more complementary than 240/9240
anyway, no mistake using any combo of these
- Babelfish M25 R.2/SET amp
