AussieAmplifiers NX150 Spyder
FastEddy said:
Jeffery:
Got any drawings or specs for the case? I assume you made this stuff at home, but it does look good enough for other hobbyists to consider ...
ED
:smash:
Hiii FastEddy
Do you understand ? 😀
That very quick explanation
i will make a hand picture
maybe can help you more
by the way, thanks FastEddy
Hi dark_avenger
The NXP180 module when released in late March will cost $89.00AUD each plus postage and handling.
Yes the best of both world, I designed it so it DIYs could build a cheap high performance stereo or HT setup and still be very small and have the ability to scale it to what ever power level you wish.
I have a thread in the vendors bazzar with more information and other comments from other members if you would like to talk about it further there.
Sorry Jeffry I do not want to highjack your thread.
I am looking forward to seeing your completed NX150 amplifier.
You are doing a great job with it. One of the best I have seen.
Keep up the good work.
Sorry i can make calculation as good as you 😀
oh yes fast eddy this is my hand drawing
about the encapsulated / chassis
You can produce there
dont forget give discount to other diy 😀
Check The Softart
Now i check the softstart
( Actualy this is the happy ending )
When i connect the AC connector
So the standby lamp is on
look the little blue light
The yellow lamp is death
( too long in solder work 😀 )
I make a fatal mistake when make this SS
I buy toroids for 2 x 12 V, but the SS need 2 X 6 V
But after Smithy666 give me some information
So the SS is ready to work now
Hi Håkan
I am in the process of updating and replacing all of my amplifier range.
I had simply sold out of those amplifier modules and rather than
do another production run of them, I will be replacing them with a new higher performance modules and I will be reducing the number of them to a more managable level.
Also I am looking at moving back to VFETs and Bipolar output stages.
I hope this helps. 🙂
