AussieAmplifiers NX150 Spyder
Encapsulated
My chasing will be unbelievable :bigeyes:
Si jopie has finished his final check in NX150 board
Maybe he work on his encapsulate now :bawling:
As my experience i will call him supreme master
if he cant finished in one week 😀
and in my opinion it will take more time
than me to finish NX chasing :hot:
New Facelift
This is the new facelift of my frontplate
Thanks alot for si jopie for his support
any comment ?
Softstart
When i receive my toroids, i was surprised, why ?
The Toroids have 45v - 0 with secondary winding
and 5A each so i start to build softstart to help
this condition
I found and build beautiful softstart
http://www.diyaudio.com/forums/showthread.php?s=&threadid=98879
Thanks Smithy, All your PCB now ready to use
The difficult thing your component really "highend"
Hard to found in Indonesia Market, Grrr :bawling:
Limited Space
Due to limited space in encapsulated so
I can't use Aussie PSU III, this happen
because in the first measurement i didnt
use the softstart, because it is important
so i change PSU III with standart PSU
Re: Re: Supply Guarantee
tinitus said:
Sorry to be rough, but you need to improve on your solder joints
Hiii Tinitius 😀
That right, I solder the rail way first than after
i put some component on it, I try to make it good,
remember the hot solder vs my standart PSU PCB
oh yes i put some copper hair on it
the pcb not in a line anymore
so thats the result...ha ha ha
FastEddy said:
Jeffery: We are looking for a case for our imported AussieAmplifiers NX150-S It looks like you might have a good start. What do you have in mind for the finish?
Mercenary announcement: We are importing the AussieAmplifiers modules and subassemblies now = http://3dotaudio.com/ ...
Hiii Bro
This is the clue :bigeyes:
All with alloy material and anodized
Regards, Jeffry
Thanks for the praise FastEddy
My nouse is like Pinochio right now
I
Front Plate
Width : 10.6 cm, Lenght : 44 cm, Thickness : 1 cm
- (width : Heatsink width + 0.6 mm)
- (0.6mm : top plate 3mm + bottom plate 3mm)
Outer frontplate shanding (elips) : 3mm - 4mm
(for top, bottom, left and right side)
II
LED Shanding ( Centre Plate )
Measure your LED than Drilling thight to hold
Than use milling machine
Width : 3cm Height : 4 cm thicknes : 6 mm
(If your LED 5 mm tall, if 4mm so thickness 7mm)
III
Bulgin switch
Drilling hole for bulgin switch (20 mm)
Milling as bulgin switch thickness 2 mm
IV
I Use Stainless block 8mm x 8mm lenght 10cm
(same as your heatsink) to unite heatsink and
front plate
make 3 hole to heatsink and 2 hole for frontplate
use 5mm screw and the screw must hold to front
plate and heatsink 5 mm deep
A
If you milling stainless block 5mm so you must
use 8 mm screw (3mm + 5mm)
B
If you dont milling
so you must use screw 13 mm (8mm + 5mm)
I give a simple picture
Hi Anthony,
can you please explain why the THD+Noise eventually diminishes at the upper audio frequencies for the NXP 180? Is it a high open loop bandwidth amp? Open loop gain is usually declining at higher frequencies and phase shift occur there making NFB less efficient.
Håkan
Hi Håkan
The Audio Precision unit that I have here which is the ATS-2
only tests THD up to 10khz the remaining drop off in THD+N above 10khz is only noise from the amplifier.
yes the NXP180 amplifier is a very high open loop design, which is why I am getting THD figures flat to 10khz.
Unfortunatley I am not able to confirm THD above 10khz with this AP unit. I would have to spend a lot more on the top model AP
to get to do that kind of tests.
I hope this helps....🙂
The Saint said:
Hi Jeffry
Good to see you have got back to completing the NX150.
Well done!
Your chassis looks excellent well done!😀
Have you seen my latest amplifier module the NXP180?
Thanks Anthony
The best part is make a perfect chasing
Very hard to do 😀
The NXP 180 look great and why dont make it car audio
Who knows The Scuderia Ferrari is waiting ... Brooom :treasure:
A lot of people here use Audison, Rockford, Sony, Alpine
Regards, jeffry
