its geting there im just working on geting rid of the the keyboard.
and replacing it with a little control pad that will sit next to it.
http://www.freewebtown.com/mpxplay/
cheers
cheers
karma said:a little control pad that will sit next to it.
Have you considered the serial or USB controllers such as those from Matrix Orbital?
http://matrixorbital.com/
Toronto is nice this time of year, I'm up here for a couple of weeks, haven't been here in 41 years. (I lived in Don Mills, ON from age 1-4.)
That Active Surplus store on Queen street is amazing.
-Rob
I made a temporary "enclosure" for the DAC. My goal was to isolate the vibrating and buzzing transformer from the DAC board by using o-rings. The wires and resistors that connect the two boards together are still too stiff. The solder easily hardens the stranded wire. I´ll have to come up with a more flexible wiring... Any ideas? Maybe I´ll try a thin copper foil.
Here's some pics:
http://www.dvdplaza.fi/galleria/showphoto.php/photo/8411
Here's some pics:
-Rob
not sure if the software works with usb but ill order one and try it.
cheers
Joined 2002
edjosh23 said:Karma,
Whats with your website these days?
By the way, what speakers are those on the table? kinda look like Infinity
And are those the Kuze3201 array back there?
Josh
YOu can't get past the username and password.. I didn't thing that was a challenge..
The speakers really do look like Infinity. The first mod to them X-over's and change the damping material behind the tweeter
Josh
i loaned my server out to a friend for a month. and yes the speakers in the corner are built around the kuze3201's un finished
DIAR said:I made a temporary "enclosure" for the DAC. My goal was to isolate the vibrating and buzzing transformer from the DAC board by using o-rings. The wires and resistors that connect the two boards together are still too stiff. The solder easily hardens the stranded wire. I´ll have to come up with a more flexible wiring... Any ideas? Maybe I´ll try a thin copper foil.
Copper foil should work fine, especially if you form loops to improve isolation.
You may also consider suspending DAC board instead, as it will be much easier to implement. Use solid core wires (22ga or so) and for signal 26ga should be fine.
BTW, some of my current products made it this month to the cover of HiFi+
http://www.hifiplus.com/latest.html
Joined 2002
Peter Daniel said:BTW, some of my current products made it this month to the cover of HiFi+
CONGRAT'S peter.. That is something that i wish to happen to me some day.. Hat's off to you..
Good on you mate... and the cover of my favorite hifi rag...
dave
Joined 2002
dave
Mine too.
Joined 2002
Peter Daniel said:I have pdf file of the review, if someone is interested please e-mail me.
Please email it to jase @ jasesspace.com
Thanks Peter..
Jase
- More Vendors...
- Audio Sector
- AudioSector-chip amp kits, dacs, chassis
