Audiopipe AP1500D issue
Yes I know it's not in protect at the moment I took the rail caps out do you want me to take the measurements again with it in protect.
The previous Gate Drive signals I sent you pics of was with the amp powered on with no rectifiers, rail caps, outputs in it that's the only way I can get it to power up
On the highside Probe ground on Source leg and probe on the gate I get a little over 1 volt see picture below.
On the lowside Drive if I put the probe ground to -12 volt terminal I get what's shown in the low side pic below.
If I take the low side Drive with the probe ground on the source leg the amp goes in protect as soon as I touched the source leg with the probe ground.
5V Regulators reinstalled same drive wave forms as before.
I redone driver board pin voltage measurements
Pin 1: -0.003
Pin 2: 0.001
Pin 3: 3.126
Pin 4: -11.43
Pin 5: 11.15
Pin 6: 0.154
Pin 7: 0.153
Pin 8: 0.001
Pin 9: 4.905
Pin 10: 0.293
Pin 11: 0.292
Ok so pin 3 of the driver board header is connected to The Collector pin on q21.
I wasn't getting continuity on the meter because it goes through a zener diode d32 and a SMD capacitor c40.
But with the amp powered on I have 3v coming from The Collector On q21 through the zener diode D32 and capacitor C40 directly to Pin 3.
So should I pull q21?
Okay I pulled q21 and the 3 volts on pin 3 of the driver board header is gone.
The low side Drive still looks about the same probe ground on -12 volt terminal and Probe on low side Gates.
1v 10us x10
The high side there is a waveform now probe ground on Source pad and probe on high side gate pad.
5v 5ms x10
Pics below of waveforms
