Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
and still pimped my toroidal transformer....with a stainless steel ashtray that I have flooded with epoxy, and previously lasered the lid 🙂 the cables are sheathed in cotton...
hello all, wanted to show my new build, so far in 3d, few parts I still have to draw. 🙂 ...
I still have to finish the outside of the case, I have extended it to the back, which is why the pattern does not fit properly on the side panels.
some other parts I still need to make (MonitorPi ect)..on the renderings you can see the IVSTD MKII output stage module...but have the OPA861 stage; still need to draw this
Cool. I actually started to model some of the boards in fusion as well. Only some have .dxf files and I haven’t had time to measure all of my boards and recreate. Nice job
@Aiello
Looks so great, so nice! Awesome design!
I just want to order a case from you for my new fully function DDC project
1. StationPi Pro
2. ReceiverPi Pro
3. FifoPiQ7 with SC-Pure 45/49
4. STC controller
5. MonitorPi Pro
6. Amanero USB
7. RPi4
8. TransportPi AES
9. HdmiPi Pro
10. UcPure MkIII 3.3V(&UcBalancer)
11. LinearPi 5V with UcConditioner 5V
Thank you so much for sharing pictures with the community.
Ian
@iancanada. Thanks for your efforts throughout your development cycle! Really very interesting and exciting. You've just made a post to @Aiello about a case, and listed a load of components that I've been shortlisting for a "target" piece of kit. My ultimate will replace the transport with DualMono DAC and I/V.
Can I ask what you're considering for the PT? I'm considering options and with the BoM you have outlined, might a 100VA 9V/9V (on 240VAC for my in UK) be overkill in terms of VA? Should I also consider smaller DC voltage taps (i.e. 6V)?
Thanks in advance for any guidence
Stunning! Can you explain what VU meters you will use and the electronics to drive those please?
@ fusion360guy
have not used dxf so far, everything taken from the respective pdf
@iancanada
for your personal case..I still like to do that 🙂
How many UcPure MkIII 3.3V(&UcBalancer) and linear pi, do you want to install?
and what is an STC controller ?
@ SimonJ
I have installed an IPS panel; which I control via volumio
here a video from my previous streamer build
It looks like they have written a custom Linux kernel to do this. See below from website. It should be possible to install new kernel to Volumio distribution as Volumio is based on open source and Linux kernel is open source. If redos release their kernel source it would be feasible.
@fusion360guy , @iancanada assuming if I have Holo Red, can I just plug in the micro SD card it comes with (RedOS) into a new RPi. Would a new streamer then be capable of doing DSD512/1024?
hello all.. got the design done tonight, and will start on the new case this weekend 🙂
