Well when I'm sitting back in my recliner sipping some lovely burbon and listening to well recorded music I like my tube amps. When I want to add some tube sound to a channel I like tube preamps. When I need 50,000w to run a stadium system I like SS for both price per watt and neutrality. They are both tools, use them as you see fit.
So what's your opinion? What are you looking for in your amp? The best that sounds to you or hi-fi?
The best that sounds to me.🙂 i prefer SS for bass and tube or hybrid for mids and highs.
my subjective description of the "sound" i like is : tight bass , clear but soft mids (slightly recessed like i like to call them) and soft crisp highs. my setup is very good in the bass department courtesy of my JBL subs
Unless you have a solo flutist playing into a "flat" mic tied directly into a cd recorder/Vinyl master cutter.....the notion of "true" music is rather pointless. Way too mach multi-tracking, EQ-ing, tweaking, etc!! Too much going on before we even pop the CD/Vinyl into our machines.
It just seems to me SS circuitry is just so much concerned with "correction", rebiasing, active corrections, etc....More effort spent "correcting" the signal than just amplifying it! Tubes are just so much more elegant, simple...After all we are just cranking it up..Precision is the implementation & paying attention to detail, quality..........not backing up like SS & correcting everything.
Kinda reminds me of Bill Gates & his cronies at Intel...."Wanna make it run better, stick a fire under the processor"(Clocking). When I was dealing with computers at the beginning, I imagined a phone-book of processors from Abraham thru Zelda.........65,535 lines of micro-data busses, a virtual Lego-block construction techniques, a true 'Core', liquid cooled 'core'............Just now some are marveling at 8--16 "core" machines, some of us are just shaking our heads of just how it COULD have been.
Seems SS has gone down this type of road.........
Now.....we have Class 'D', quite intriguing this new stuff.........I will skip SS altogether & embrace the 'new'......while still fawning for the masterful glow of tubes.
___________________________________________________Rick........
Why not look into refining class D?
Whats there to refine ...?
I won't even get into tubes as that isn't high fidelity. Boscoe
Yes ...... this will be good .....😀
Read any of my articles on my designs, look at the performance, then tell me how they are insufficiently accurate.
Articles, Times , news week ......? 😛
Ohhh no ................ More !!!!Okay last post for tonight (who knows forever!?)...
Generaly , tubed sound is really , well , a tubed sound....
Uhh huh ......😉
And SS sound is really, well, a SS sound.
Uhhh Huh ....... 😉
As I said before, my beasts when produce -80 db of second only harmonic still sound like tube beasts. 😀
I mean, warm, clean, and transparent. No grain of "sterile morgue sound".
Is it bad, or good? 😉
What deh Denon ..........?
No. Lower THD and high DF numbers do not mean lower distortions. And if to combine all existing SS amps and calculate average distortion numbers, then combine all existing tube amps and calculate average distortion numbers, I am pretty sure tubes will definitely win, not only because no tubes in cellphones, car players, TVs, etc, but because real melomans prefer tube amps, so more of effort goes to their design than to design of cheap mass production receivers.
Yeah , thats why you listen to tubes instead of your denon ....
Yes, and low DF does not cause distortion (as claimed by Boscoe) but frequency response peaks.
So frequency response peaks does not produce distortion ....? 😱
Because real melomans prefer tube amps, so more of effort goes to their design than to design of cheap mass production receivers.
As oppose to fake melosmans ...? 😀
Yeah , thats why you listen to tubes instead of your denon ....😛
No, that's why I can't afford my own designs. When I have some finished prototype I enjoy it, until it's gone to somebody who can afford it.
And what if you were listening to a good recording of the 50KW stadium system? Would you use tubes? 😉Well when I'm sitting back in my recliner sipping some lovely burbon and listening to well recorded music I like my tube amps. When I want to add some tube sound to a channel I like tube preamps. When I need 50,000w to run a stadium system I like SS for both price per watt and neutrality.
Where can i see one of these beasties ...?
Careful .... toobeys think they can ......🙂
...a good recording of the 50KW stadium system?
No such thing. Stadium sound sucks.
In your living room. If you can afford one, of course. I have some 200W monoblocks on staples.
200watts ..🙄
Wouldn't even tickle the tweeters .😛 So nothing to see, what's it called Pussin-abag 1.0... 😀
What do they compare to ? are they SET, PP...?
They are PP. Compared may be to other Wavebourn Pyramids.
However, they will drive line arrays on freqs above 150 Hz, for lows class D amps will be added.
Well you should get one, i heard they may be good .....🙂
Toobs are not in my immediate future, i'm currently into big, low-z, low sensitivity "transducers" 🙂 had my fair share in the past , no plans to go there anytime soon...
and no tubes are not better than SS , nor SS better than toobs .......... Different ? application ?
Doesn't have to. Much of it is fighting dreadful acoustics.No such thing. Stadium sound sucks.
Don't be gettin' the tubies to start thinking about "Stadium sound", they'll be thinking about tubes the size of trashcans........then your 'stadiums' will be sporting bass horns the size of Greyhound buses.
________________________________________________________Rick........
- Member Areas
- The Lounge
- Are you really interested in 'Hi-Fi'?
